Results 1 to 2 of 2
Thread: can i use this diff in a vt
    vt commodore
    May 2010
    Default can i use this diff in a vt
    hoping someone can help
    i have a vt coomodore diff was noisey with irs and when i pulled it out found the diff is dirrent to the one i got, replacement has no teeth on the side where the plates are for axle and no holes for the sensors , can i still use this diff, same ratio is marked on them
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Not really, unless you can transfer the back cover over from your old one so that you don't lose ABS. Are the "teeth"/ short axles interchangeable?
    It's not worth downgrading your cars safety to save a few bucks.
  1. [VIC] FS, VS Stato door trims, VR Diff and VN Diff.
    By slepar in forum Parts And Other Items For Sale
    Last Post: 31-01-2010, 11:23 AM
  2. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  3. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  4. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  5. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
