Got vy commodore seats and want to slap them in my vt i know they bolt straight in but im not sure about the wiring as my vt only have 2 plugs and the vy seast have 3 orange plug ,yellow plug(Seat belt light) the orange plugs are diffrent ive noticed 1 is larger then the other.and a large white plug with a sticker on it says (Vx module GM) that i have no idea what it does
Anyways has anyone got a diagram or able to quickly help me out with what to do.
Real cars don't power the front wheels, they lift them
The sign on the side of the VY seats says (GMH VX SIAB MODULE) aka side impact airbag , im wondering if i dont plug that into my vt will that affect my main airbag system? as im sure the vt does not have SIAB(Side impact airbag)
looking at the vt car wiring harness i have a orange wire and a black wire(power and earth)
On the vy seat i have Red,black and black with white stripe, Anyone able to shed some light on what wires i should join and where they go etc please
SIAB in a vt are seperate to seat electrics. You can plug in the seat electrics without risk.
If your new seats have SIAB and your old ones didnt, there wont be a witring harness to use them. From memory, in a VT the seat connector is seperate to the SIAB connector.
If you dont hook up the new seats airbags, it wont cause any troubles - assuming your old seats didnt have them. If your old seats did, and the new seats have a different connection - not hooking them up will cause a rising 3 beep sequence to sound in the dash - repeated 3 times - at start up, and your airbag light will come on. All other airbags will still function. If you pay someone to disable the seat airbags and they do it wrong it WILL disable all the airbags. You have to reduce the number of active airbags, not disable any airbags.
