Results 1 to 3 of 3
Thread: left hand thread? bolt or stud with nut attched
    vt olympic edition 99 model
    Apr 2010
    Default left hand thread? bolt or stud with nut attched
    hi guys ive run into a prolem doing the engine mounts on my car someone has round the nut off between the air compressor and the block i cant not for lthe life of me get it out
    ive now called ThreadTech this company they can remove it for 90-150 bucks
    my question is the stud or bolt what ever it is left hand thread . and is it a studwith bolt attached or is it just a nut that gets remvoed from a stud?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's right hand thread but I'm not sure on the other question because I'm not sure what you mean, but I think on the bracket that is on the engine it's bolts holding it on and on the mounts it's nuts on studs.
    MY RIDE
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Get some vice grips on the rounded off nut or use a Metrinch socket or spanner.
  1. [VIC] VZ left hand headlight protector
    By jet-6 in forum Swap / Wanted to Buy / Trade
    Last Post: 17-05-2009, 09:29 PM
  2. [SA] left hand red door
    By Phat VN in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2009, 10:45 AM
  3. Sphere under left hand side
    By KnobMuffin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 01:13 PM
  4. VT rear left exhaust manifold stud broken, remove with easy out or don't attempt
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 02:38 PM
  5. Removing Left hand mirror
    By strat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2006, 11:47 PM
