Hey everyone i got a bit of a problem with my trac off light it has started to flicker..
After i start the car I always turn trac control off (HATE IT). Not long after i have done this it starts to flicker and also no matter what speed i doing 0, 15,40,80 or 100klms its flickers the same rate. Have attached a video of what it does.
Any ideas on where to start to try and fix this.
I had a similar problem where my traction control light was on all the time.
Did a search and found out traction and brake lights are on the same electrical circuit.
Went looking and found that somehow the holder for the brake light in the back window had been broken. Put a new globe in and stuck it all back together with a heap of bluetack. Traction control light went out.
Have a look round, maybe one of your globes is loose or something?
Hmmmm will look into that cheers
Had a look at what was said above and can not fault at all. Also cleaned all the ABS sensors front and rear just incase that was causing it. Also cleaned out the abs plug under the bonnet too. But still no joy..
Anybody got anymore ideas...
