Results 1 to 5 of 5
Thread: Spring clamps neededh
    Red 1999 V6 VT Commodore
    Jan 2010
    Default Spring clamps neededh
    Hey guys got everything and ready to throw my superlows into my vt but now I need to get my hands on to spring compresors, so I am just wondering if anyone out there knows were I could get some or hire some?
    Thanks for any advice.
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Jan 2010
    Jan 2010
    Yea mate pretty acurate with the price you gave me I pick a pair up for 41 bucks cheers mate
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can do springs without compressors. I did a full set on a VZ sedan in an hour.
    To do the fronts: With everything in the car and the car on the ground, undo the top nut, remove the plate, undo the next nut and raise the car slowly untill the wheels are off the ground and remove them. You can then undo the bottom two nuts that hold the strut in and remove it all. There is not enough tension on anything to make it fly apart. Fit the new springs with the strut out of the car, super lows are low enough to not need compressors to fit them, just push the top mounting plate down while holding the strut shaft up and fit the nut. Do it up and refit all the other bits then refit the unit back inot the car.
    To do the rears: With the hand brake off, raise the rear of the car, remove the wheels and using a lever, prise the old spring out, then just place the new spring in, keeping in mind which way is up of course.
    Visit my Facebook page
  1. Radiator Hose Clamps
    By Sean880 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-11-2010, 10:14 PM
  2. Spring Clamps
    By Robbo VS3 in forum General
    Last Post: 13-11-2009, 01:57 PM
  3. [VIC] t bolt clamps
    By jaisvz in forum Swap / Wanted to Buy / Trade
    Last Post: 29-09-2009, 01:32 PM
  4. Radiator Hose Clamps..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2005, 08:29 AM
  5. Spring Steel Radiator Clamps...
    Last Post: 05-12-2005, 05:38 PM
