hi i dont know much about vts my dads vt is having a couple of problems 1. the car wont start when its hot just sounds like it has a dead battery havent mucked around with it yet only started happening a couple weeks ago but when we put the jump starter on it it starts straight away and it starts fine when the engine is cold and 2. the drivers side window wont come back up (power windows) gotta sit there for ages usually around 10 to 15 minutes to get it to go back up we tried dry lube didnt fix it and also graphite powder and that didnt fix it any help would be greatly appreciated![]()
ok was the starter motor picked up a new one thrwe it in and she is starting fine now still cant figure out whats wrong with the stupid window though
mmm loving my VR
You could try silicone spray where the window slides as a fast fix but it seems like you are going to have to pull the door trim off and do a proper search for the fault
hey sorry about the long reply the silicone spray worked thanks heaps![]()
Starting issues might be crank angle sensor. I was told to poor cold water over the harmonic balancer (CAS behind that) then try and start.
Originally Posted by Yoda
