Hi all,
Ive run into some trouble attempting to install a berlina roof loom harness, which includes the berlina centre dome light with two map lights, and two rear courtesy lights that sit above the back doors next to the grab handles.
Ive installed the new loom removing the loom which attaches next to the drivers pillar floor. Pluged in the new centre dome light and two rear courtesy lights. Now when the door is open all lights come on execpt the two map lights on the centre dome, i press the individual bottons for the map lights and nothing happens, still wont come on.
I had a play around with the dome, when i move the switch to door/off/on nothing happens, regardless of door open or closed the light stays on while the door is open. Once i close the door the centre dome light and two rear courtesy lights turn off as normal when switch is set to door. If I put the switch to off or on doesn't matter doesn't work, light on only when door is open then off after 20secs when door is closed.
Now i realise the berlina loom has a purple wire running from the centre dome through the loom, when it gets to the loom plug on the floor there is 5 wires compared with the executive loom which only has four. Of course been an executive the other end of the loom only has 4 wires. therefore the loom is not working correctly.
Does anyone know how to combat this issue?? Can i splice a purple wire from the floor harness into the loom conection to provide the missing wire in the floor harness? If so does anyone know where i can get this wire from in the floor harness.
Attached is photos to better explain my issue. Any help much appreciated, if i can work out how to fix this issue i will write up a how to as i couldn't find one on the forum.
my understanding of the standard type interior switch should be 4 wires
constant
earth
door controlled on/off
earth
i would just splice the loom behind the switch itself that has the constant for when you turn the light to on, to the power for the individual lights, that should fix the problem
Stevoss thanks for the reply, however i am not sure as to which wire is what, attached is two pictures, one of the executive loom wite, and one of the berlina loom wire that attaches to the interior dome light.
executive loom contains: yellow, orange, black white (green stripe) left to right
Berlina loom contains: orange, white (green stripe), purple, yellow left to right
it would be great if someone could have the answer as im having the same problem also, i used the standard s pac wiring loom and was thinkin of getting a vy berlina wiring loom so i can also hook up the sunglass holder compartment between the sunvisors.
if you work it out please do up a how to do thread
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
