Results 1 to 4 of 4
Thread: adjusting revs and special mode on the cluster
    VX S pack
    May 2010
    Default adjusting revs and special mode on the cluster
    hey
    i was wondering if anyone knew how to adjust the idle revs because my car is idleing way to low and is really rough
    also i was wondering how to get the different mode on the cluster because my mate has a VT 99' and he can make his cluster show different stats like digital speed and litrs left in the tank by pressing mode up but it doesnt seem to work in my car
    does anyone know???????? either answer would be greatly appreciated
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Hold the mode and up buttons, turn the ignition on and release the buttons, then press mode to scroll through the various options.
    the idle can't be adjusted so you might want to look at the IAC valve which could be causing the problem. Sometimes cleaning the IAC valve can fix tew problem. Also a vacuum leak can cause poor idle.
    MY RIDE
    VX S pack
    May 2010
    thanx heaps man that helps alot i checked the forum on faults and it also says it could be the surge pipe but yeah thanx for the cluster help
    by anychance is it expensive to fix that problem
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VX S-speeddemon View Post
    Cleaning the IAC valve is simply a matter of undoing 2 screws, unplugging the wiring connector, removing the IAC valve and cleaning it with throttle body cleaner or carby cleaner. The purge hose should be simple to replace if necessary, just check to see that it hasn't come off.
    MY RIDE
  1. VX mode button/ cluster lights/fuel gauge all gone??!?!
    By tigermica in forum Electrical Wiring / Questions
    Last Post: 04-02-2007, 03:02 AM
  2. how enable hidden mode on 99 vt cluster also is a super charger worth it/////////////
    By 99vtwgn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 05:16 PM
  3. Vn 5Lt Diagnostic Mode How To Put The ECU Into This Mode
    By scotty1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 06:12 PM
  4. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
  5. VT speedo cluster "special" features?
    By bdcmedia in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2004, 04:15 PM
Tags for this Thread
