Ho7den
- Jul 28, 2005
- 24
- 0
- 0
- Age
- 45
- Location
- Nelson, New Zealand
- VX Executive
For those of you who where interested in the mounting of lights under my door handles, here is the finnished product.
One night I had a thought about putting some LED lights under the door handles of my VX Executive when I could not find the door handle (no I was not drunk), so went onto the internet to see what I could find and came up with these for $2 each
http://forums.justcommodores.com.au/attachment.php?attachmentid=4375&stc=1.
Then came the fun part of playing around with them to get the desired effect that I wanted. If I mounted them to high under the door handle you could see the light comming out between the gap at the top of the door handle, if you mounted them too low you could actually see the LED. Once I figured out where I wanted them I drilled a small hole big enough for the wires to go through but not the LED.
http://forums.justcommodores.com.au/attachment.php?attachmentid=4376&stc=1
Then I hot glued the wires at the back of the door handle so as the light would not pull through.
http://forums.justcommodores.com.au/attachment.php?attachmentid=4377&stc=1
Once all the LED,s had been mounted it was just a matter of wiring them up which I thought was going to be a problem but turned out to be pretty simple. I ran wires through the door and into the cabin via the main wiring harnes by using a curtain rod with closed eyes at either end. Down the side of the car under the scuff plates and up the pillar, acros the roof and out where the interior light is. Then all I had to do was connect them to the positive and negative of the light but remembering that they are opposite.
http://forums.justcommodores.com.au/attachment.php?attachmentid=4378&stc=1
