Results 1 to 3 of 3
Thread: Quick question Re: Growler Temp sensor
    99 VT Acclaim
    May 2006
    Traralgon, Victoria
    Default Quick question Re: Growler Temp sensor
    So I finally got around to installing my Growler in my VT, but it says to install the Air Temp sensor in the pre-drilled hole.
    Problem is, there's NO pre-drilled hole. I've googled, searched this forum with no luck in finding an answer. The SSinductions site is no real help either.
    Where does one put the sensor?
    Thanks for the help
    VT Commodore
    May 2010
    I got the same kit for my vt. it should be on the part that connects to the MAF sensor
    99 VT Acclaim
    May 2006
    Traralgon, Victoria
    Quote Originally Posted by Helrza View Post
    There's no holes there apart from the main one that you put the hose that has the MAF sensor on it.. There's little slots at the tip of the bit where the hose goes, but thats about it.
  1. Engine getting Hot quick but not going over half on temp gauge?
    By HSV.421 in forum V8 Development and Modification
    Last Post: 06-03-2010, 11:23 AM
  2. temp sensor
    By alex2_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2009, 08:21 PM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. quick temp question..
    By goat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 10:09 PM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
