i have another problem wit my drivers side door. wen i open and close it, it makes a loud grating noise , i have already put wd40 spray on it and it still no good jt wondering wat i have to do
i have the same prob, but on my right rear passanger door, tried spraying it also and didnt work :S
You probably both need to replace the check strap, which is the thing that stops the door from opening all the way.
MY RIDE
Yep that's what it will be. Though when I tried to fix it the other day, something broke, now it won't stay open by itself
oh k then kool thanks for that i thought it wud be something to do wit the bolts or something lol but thanks for that guys
on mine the check strap bolts were loose, so i just tightened them again and it was good as new
oh k thanks for the help guys much gratefull
door check straps need to be greased, not WD40'd
I haven't lost my mind, it's backed up on tape somewhere
