Results 1 to 17 of 17
Thread: LS1 Misfiring after installing extractors
    hfcmad's Avatar
    hfcmad is offline Buddy Marvellous
    VT SS S2
    Sep 2009
    S/E Melbourne
    Default LS1 Misfiring after installing extractors
    I got a set of extractors installed & now the car is misfiring under load
    If I drive it around normally I have no issue but when I put my foot down to pass a slower car it's starts spluttering & I lose power and it's starts backfiring until I back off of the throttle
    Mafless tune was done with standard headers attached
    My car
    VT SS II
    Mafless Tune
    OTR
    2.5" Cat Back
    Standard Cats
    2.5" Tri Y's
    I had no problems until I got the extractors installed
    Please Help
    Thats What I'm Talking About !!!
    VS SS
    Mar 2009
    check all your leads are on properly, they could of been moved around with the fitment of the extractors
    VT II supercharged s pack and VY lumina
    Jan 2010
    misfiring or backfiring???
    perhaps check your
    your oxygen sensor, might be playing up or not installed properly, or your spark lug lead/spark plug has been damaged
    VY II V6
    Dec 2006
    It will most likely be the spark plugs and/or leads.. I'm guessing a lead may have gotten damaged..
    VT SS S2 A4
    Aug 2005
    VY Acclaim Wagon And VX SS
    Jan 2007
    Sanctuary Point
    I've just gone through the same issue ,checked plugs and leads and they were fine ,removed and cleaned 02 sensors ran fine for a couple of days tryed cleaning the sensor again didn't work
    so have just put in New sensors and is running Beautiffly .so i would have to say its the o2 sensors .Good Luck
    GO HRT
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Sometimes the porcelain on the plugs can be cracked. Pull them out and check them. After 7 years without, i put on extractors and my original oxys are still used. They sometimes get stuck and can get damaged when pulling them out.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I would check the plugs too, I have seen a few get cracked removing and replacing them when fitting extractors. Leads can sometimes pull away from the connector when removed from the plugs too, so that could be your problem. Check them with a multi meter, the one that has zero resistance will be the culprit. The spark will jump fine while there is no load on the engine, but once it loads up then it will misfire.
    Visit my Facebook page
    hfcmad's Avatar
    VT SS S2
    Sep 2009
    S/E Melbourne
    I changed the plugs today, But still have the same problem,
    So I removed all of the leads & reconnected them & it helped a bit so I'm going to replace them tomorrow
    VX exec
    May 2009
    if they are stock leads, i also had the same problem with the old mans car... the electrodes inside get damaged... was like new with a new set of leads...
    hfcmad's Avatar
    VT SS S2
    Sep 2009
    S/E Melbourne
    The new set of leads don't have the removable metal sleeve like the factory leads
    Do I reuse the metal sleeves or not ????
    2000 VT S2 Olympic Ediiion
    Feb 2010
    yes use the metal sleaves clean them before reusing the are there to protect leads from heat/melting i guess
    davleigh's Avatar
    davleigh is offline Donating Member
    Vx SS Commodore
    Feb 2012
    just in regards to this. if you have an otr, mafless tune, 2.5in cat back. then you install headers.
    do you need to get a new tune? or is it only once you install a cam that the tune needs to be re done?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    you can have it retuned but only if they would do it for free - not worth it if you have to pay
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
  15. #15
    davleigh's Avatar
    Vx SS Commodore
    Feb 2012
    ok. cos i am getting my otr cai and and mafless done tomorrow. i only have a cat back, msd leads and platinum plugs atm but i am looking at going vy hsv headers down the track. just needed to know that lol.
    i didnt wanna install the headers and then have to go retune it
  16. #16
    davleigh's Avatar
    Vx SS Commodore
    Feb 2012
    mafless tune done and otr installed.
    also now have a full vz clubby exhaust to fit on the car.
    do you know what kinda improvements this might give?
  17. #17
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Well the tune an otr should net you 15-25rwkw, The exhaust will get you another 10-15rwkw if re-tuned maybe 5-8rwkw if not. These are just ball park Figures.
    You really should have done all the bolt on mods 1st then got the tune done, because to get the most out of the exhaust you will need a re-tune.
    Also im fairly sure that the 'headers' on the vz ls1 clubsport are the same cast mainfolds that your vx ss have so no better the vy clubsport had ture headers. so what im saying is you will still need a set of headers. (I could be wrong)
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  1. installing extractors cost ??????
    By sawychri06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2010, 11:33 PM
  2. Installing extractors V8
    By BHAZA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2010, 04:42 PM
  3. Installing Extractors to a VP V6
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 05:41 PM
  4. installing extractors
    By vs-s-pak-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2006, 06:39 PM
  5. Installing Extractors
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2005, 11:02 AM
