Results 1 to 4 of 4
Thread: missfire
    01 ute manual
    May 2008
    Default missfire
    Gday i have a vu v6 manual and i have a missfire not under load. If i just touch the throttle it missfires and when i give it a bootfull its fine. Iv read post on missfire undr load but mine is different. If i start it on a cold morning and just gentally ease the throttle it just coughs for a bit then picks up. I just dont want to go spending hundreds on replacing everything when it could be simple. iv replaced plugs. Another thing is i now run it on bp ultimate and it seems to be a lil better but its still there any help is much appreciated thanks
    vt commodore
    Apr 2010
    vt ecotec
    Sep 2009
    I have similar issues, but have a few mods to contend with such as after marker supercharger roller rockers, injectors etc - miss-fire under load / heavy acceleration, like the timing is slightly out,also at high revs around 5000 rpm "holding back". At times backfire through inlet manifold when you "floor it" - ? coil pack, ? fuel filter, ? leads / spark plugs and ? chip issues.
    under normal driving its relatively O.K any ideas much help before I spend $600+ $
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Quote Originally Posted by sradman View Post
    Sounds like your engine is running too lean
  1. vp missfire
    By godsey265 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2009, 01:25 AM
  2. Vn Missfire
    By jetoblaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2008, 08:24 PM
  3. random missfire
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 04:02 PM
  4. Missfire at idle...
    By Sorak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:09 AM
  5. Vs Missfire
    By Chris Everett in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2004, 05:56 PM
