Results 1 to 4 of 4
Thread: Engine change
    vx
    May 2010
    Default Engine change
    Hi. I am going to put a vs engine in a vx. Can i bring the vs engine up to the vx kw rating and is there anything i will need from the vx engine.
    Thanks for your time
    vx
    May 2010
    Default More info
    Quote Originally Posted by snibbo View Post
    I have found out that a vs 3.8 Ltr v6 engine produces 147 Kw and the vx engine produces 152 Kw, The only difference i can find between the two is that the vx engine has a upgraded inlet manifold and indvidual spark controle. Can anyone please tell me if the vs and the vx have the same came sharfts and what i have to do to bring the vs engine up to 152 Kw. I am going to fit the vs engine into the vx because the vx engine has died and i have a good vs engine in the shed.
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    a good cold air intake will prob get you there,
    you might want to check the laws about putting a older engine in a newer car before you start, make sure it doesn't exceed any emission laws or whatever
    vx
    May 2010
    Thanks Jay. I have since found out that the vx engine had an updated inlet manifold and somthing called individual spark controll so, if i use the vx inlet and electronics that might do it. I would like to know if the vx and the vy have the same cam sharft profiles.
  1. VN engine change.
    By massacred in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2010, 05:55 PM
  2. VR UTE engine change
    By vr_uteris in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 06:29 PM
  3. engine change
    By skyper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 11:53 AM
  4. engine change vr-vx (v6)??
    By bomner12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 01:18 PM
  5. VX to VL Engine Change - Possible
    By DriversMate in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2005, 07:39 PM
