hey guy when i give my charged vt a bit it looses all power and the low traction light comes on than its all good could this be caused by a hole in the muffler on the exhaust or something else
any help is much appreciated guys
How about you try and turn off the traction control and see if it loses power (if it does not) it's the TC system doing what it's supposed to do when its on.
yeah it does it when the traction is off as well its like it loses all the power when you try to give it a bit
Well check you spark plugs and replace, replace you leads if still not better than your oxygen(o2) sensor going into you headers closer to the rear of you engine.
