Results 1 to 11 of 11
Thread: Having a problem with my seats after fitting vy seats to my vt.
    2010 Holden VE SIDI SV6
    May 2009
    Default Having a problem with my seats after fitting vy seats to my vt.
    hey all,
    i brought seats that came out of a Vy berlina and went into a 1999 Vt ex. i had a some problems first the wiring and plugs were differnt to the vt ones so i had to cut and join the normal vt plugs to the vy. Then i plugged the seat belt in and when i started up the car the airbag light came on. i have looked at the wiring too many times and nothing has changed, any ideas why it does it because its driving me crazy.
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    I guessing it relates to the fact that the berlinas have side airbags while the execs don't. There must be a change in the wiring bcos of that. I put VZ seats in my VT, both both cars were berlins so there was no real issues.
    May 2009
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    take it 2 holden and get them 2 reprogramed the ecu to suit no side airbags
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX SS 5.7
    Mar 2009
    North Adelaide
    Did you have the seat belt pre tensioners unplugged and the ignition on? That may have caused an error code to be logged...
    Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
    Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
    car
    Jul 2006
    greensy, melb
    yeh you need to disconnect the battery when you disconnect the seat pretensioner wiring otherwise it logs the error codes and they stay on
    "A life lived in fear is a life half lived"
    May 2009
    Default what to do?
    what should i do take it to holden or is there something i can do like take the batt out for 10mins or so? if i take it to holden any idea how much its going to cost?
    VX SS 5.7
    Mar 2009
    North Adelaide
    Have a search on here and see if there is any way to read codes and clear them....you might be able to clear them yourself otherwise you'll have to take it to holden and they can use their tech 2 to clear codes etc.
    vt acclaim gen 3
    Jul 2009
    vic
    Did the seats come out of a crashed car? Because when i put my leather seats in my vt the air bag light stays on because the car i got them out of them had been in a crash and pulled the pretensioner. To fix this problem apparently i have to replace the pretensioner and clear the fault code according to the mechanic that checked it with a scan tool. hope this helps!
    henrytad
    hey everyone, ive always liked the noise of a blow off valve hissing at the change of gear, n was wondering if there is a way to hook one up on a alloytec 3.6L without a turbo?
    May 2009
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You can't clear an airbag fault light without a Tech 2. If the ignition was turned on at any point with any srs wiring disconnected, it will log a fault and the light will stay on until cleared.
    Visit my Facebook page
  1. Fitting Seats VT onwards in VR
    By captaincruncher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2010, 08:48 PM
  2. VP VN (VR?) seats fitting VS?
    By Silver_VS_II in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2009, 01:29 PM
  3. fitting bucket seats alot involved?
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2008, 06:56 PM
  4. fitting aftermarket seats
    By Bubbles in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-08-2005, 08:05 PM
  5. Sparco Seats Fitting
    By Bugnash in forum General Discussion
    Last Post: 18-07-2005, 08:13 PM
