Results 1 to 2 of 2
Thread: Watery oil help
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Watery oil help
    changed inlet gasket foudn it to be leaking done a compression test and got 180psi per cyl
    Anyways can someone give me some advice on how to really clean the radiator out since it seems like its full of oil (V6 Auto)
    Real cars don't power the front wheels, they lift them
    VT Acclaim Wagon
    Oct 2008
    I suggest you buy a litre of soluble oil, the stuff machine shops use (mixes with water) and let enough water out of your motor so you can pour the oil in. Run the car normally for a couple of days so all the motor oil is picked up then drain and flush your motor and radiator, your manual if you have one will tell you how to do this. Then get a good radiator cleaner and use it according to instructions. If you dont have a blown head gasket, this should fix it
  1. watery sound from behind dash
    By greenvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2008, 08:46 PM
  2. Watery sound in cabin
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2005, 07:19 PM
