hey guys recently found out that my ac lights in the dash are out and was wondering how i remove the a/c power button, the a/c temp and the a/c direction just the whole a/c console if anyone has an knowledge can u maybe put some pics on to show us or tell me wat i need to do
cheers
cheers
remove the centre console plastic and dash fascia. then the climate control unit is held in by 3 screw. remove these and disconnect the electric connectors. leave the vaccum switch connected but remove the switch itself from the control panel. then the control box should come off...unless its different in VX compared to VT... i've recently found about 9 illumination lights blown so my dash is in pieces.
do i just try and pop it off or are there screws i need to undo
but i will give it a try
thanx heaps
MY RIDE
From memory: You're going to need to pull down the panel near the drivers feet, theres 4 screws there, Where the cig lighter is there's another 2 screws, Theres 2 where your dash cluster is, there the ones I can think by memory... You also may need to remove the center console after removing the screws near the cig lighter it should just pop out, And theres 2 screws just behind when you pop that out that you may need to get..... I'm sorry If I've missed anything....
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
thanks heap guys you've been a great help
