Results 1 to 11 of 11
Thread: V6 oil Questions
    VT SS 5.7
    Mar 2005
    Goulburn
    Default V6 oil Questions
    Long story short, there is oil in the radiator
    Compression test on the motor comes up at 180-psi per cyl
    Oil in the motor looks to be black ...oil cap looks slightly milky
    Drained the oil poped gtx2 and new filter in now the oil looks REALLY milky
    Any advice?
    Car seems to run 100% perfect not a miss or any sounds out of normal
    Real cars don't power the front wheels, they lift them
    04 vz clubsport, 6L M6
    Oct 2008
    radelaide
    did they do a proper leak down test or just a quick compression test?
    you could have a split in the head gasket, or even a cracked water jacket
    and if there is water in you oil i wouldn't be driving it, the oil will no longer be doing it's job and the internals wont be getting the lubrication they need
    04 z series clubby. 6 litre 6 speed manual
    Quote Originally Posted by Cúl-Báire View Post
    Stroke and Blow it for extra fun!..
    Quote Originally Posted by DM 55 WA
    thats only because instead of porn i look at pictures of your ute!
    VY II V6
    Dec 2006
    VT SS 5.7
    Mar 2005
    Goulburn
    it running on external core tranny cooler,
    did a leak down test and seems to be good holding pressure
    before i changed the oil ,the oil was black and the car haddent been started in about a week
    just wondering if it is possable that the sump might of had abit of water and its just smashed it all together?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Could be a leaking inlet manifold gasket. Check the bolts to see if they are loose.
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by Tree cutter View Post
    Bingo. These things are known for degraded intake manifold gaskets. That will be your issue
    VYII Calais L67
    VT SS 5.7
    Mar 2005
    Goulburn
    its had a new ACL inlet gasket kit for about a week so far , think it could be the new gasket?
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    im guessing cracked/blown or rooted head gasket mate id say get ur heads replaced go to the wreckers and pick 1 up for cheap just make sure its for ur car i had the same problem when i first baught my car had to replace the head coz it was the same only to find out 2 months later i blew the engine driving it thinking it was nuthing to worry about bro if i were u dont drive it and get a second hand head gasket the service it again and im sure ull be ok
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    VT SS 5.7
    Mar 2005
    Goulburn
    Cheers mate thanks
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Yes it could still be the new gasket. Did you install it with a coat of sealant or hylomar spray ? Did you put the blobs of sealant on the ends of block ? Like you me and many others the ACL gasket is a shitty plastic one the same as what was in there before. Has caused issues to millions of gm cars around the world this stupid gasket. Anyway, it may not have seated properly and also only run water in engine for first 100 k's.
    VT SS 5.7
    Mar 2005
    Goulburn
    Hi mate yea i thought that might have been the case so i riped everything apart again and checked to make sure it was alla sealing 100% everything looks to be good, i was maily focused on sealing where the water jackets run
    im going to drop the oil out of it again today and drop some new stuff in to see if that might be abit better
    sorta hopign it was just water in the sump that didnt drain when i first drained it
  1. vp questions
    By sawychri06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2010, 01:18 AM
  2. vs BCM questions
    By GTS2 176 in forum Electrical Wiring / Questions
    Last Post: 08-01-2009, 10:42 AM
  3. few questions..
    By bindme_87 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-01-2009, 04:21 PM
  4. VK Questions
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2005, 12:07 PM
  5. 97 VT WGN Questions
    By gZ-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2005, 11:50 AM
