Hey guys,
the temperature control for the ac and half of the ac light does not light up anymore and i was wondering how to fix it? im guessing that its one light that does this particular section
any guides or likewise would help greatly,
cheers in advance
I have a VX Acclaim (same AC unit) that had the same problem. You will need to take out the whole dash trim eg around your dash cluster cd player that one bit bit of trim manage to take that off there's 7 screws I think. Take the trim off them once you get to the unit it self there are 3 screws holding the unit in, take them out. Then look at the back of the unit for black circle things on the brown board, then unscrew all 7 of them. Even if all of them aren't blown replace all because if you do half the other half will blow in about a months time. But the downside to this all is you cant just replace the bulb you have to replace its little housing too which comes to $7-8.50 EACH bulb/ black housing thing from Holden. Good luck.
