Results 1 to 6 of 6
Thread: VT seatbelts
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    Default VT seatbelts
    hey
    just quickly, its a niggly little thing that annoys the shit outta me and i can survive without fixing it but i was wondering if theres a way to fix the rollers (im guessing?) for the seatbelts in a VT Acclaim?
    the seatbelt havent rolled up properly for a while and they only do when i practically feed it in or hold it at a certain angle, so any guides or suggestions would be welcome
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I have the same problem with my driver's belt. I haven't got around to fixing it yet but when I do I will pull the retractor part out, give it a good clean and lubrication and that should fix it.
    MY RIDE
    VXII
    Nov 2009
    Good luck. Seatbelts aren't designed to be disassembled and repaired, and it is illegal to do so for safety reasons. It may feel like it works properly when bench tested, but may fail under crash conditions.
    All the internals will fall apart if you are able to unlock the metal tabs. Pull it apart to learn by all means, but have a new one to replace it with.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by moose man View Post
    I don't intend to pull the ratractor part apart, only unbolt it, pull the belt out as far as it will go, clean all the dirt and dust out and lubricate the moving parts. Which is what I said in my reply to the OP. I don't foresee any problems there.
    MY RIDE
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by accentstencil View Post
    when you go to do this, do you mind giving a step by step when done, as i need to do this on my passengers side
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by lufkin View Post
    No problem, I'll get around to it soon because it is annoying. It may not fix the problem but you never know unless you have a go.
    MY RIDE
  1. Adjustable Seatbelts
    By NORTI in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2009, 07:38 PM
  2. VR statesman seatbelts
    By Sgt Santa Cruz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2009, 11:09 PM
  3. Seatbelts
    By EmmY957 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 03:19 PM
  4. Tightening seatbelts?
    By Dougeh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 12:19 AM
