Results 1 to 1 of 1
Thread: WH Statesman Coil Pack
    PhD
    PhD is offline
    WH Statesman
    Mar 2009
    Default WH Statesman Misfire/Shudder under load and at idle
    Hey guys,
    Im getting wierd shuddering/misfiring lately, and ive replaced the leads, plugs and crank sensor and its still doing it - so i decided to test the coils... thikning maybe its that.. but they seem to be ok..
    Ive read that the resistance specs are supposed to be, 0.3-1.5 Ohms on the primary coil (the underside of the coil where the prongs that stick out of the dfi module plug into) and 5000-7000 ohms across the secondary terminals (the ones where the leads plug into on the coil itself).
    ive got the multimeter set to 20K on Ohms...
    and each coil is:
    6/3=5.60
    5/2=5.49
    4/1=5.60
    These translate to 5600, 5490 and 5600 ohms right? - so these look well within range...
    On the primary coils - they are each 1.2ohms - so it looks like the coils themselves are ok...
    How do i test the dfi module if its working ok or within the right range?
    On the dfi module - reading the ohms across the pins there i get 16.73 kOhms across each set of pins... is there some value there that they are supposed to be between?
    The only things i havent changed are the cam sensor and o2 sensors... .. the shuddering is when under load and even at idle at the lights - but it comes and goes, some days it will do it - others it wont... any other ideas?
  1. vp coil pack on vr ???
    By adz86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2009, 10:27 PM
  2. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  3. coil pack vp-vs
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2008, 11:16 AM
  4. coil pack /dfi
    By gold_vienna in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2008, 05:22 AM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
