Hi all how hard is it to put new engine mounts in vt with out pulling motor out and does anybody have anyspare?
It'd be a major pain in the arse to do them without a hoist. But probably do-able.
Originally Posted by Reaper:
Originally Posted by Jecs:
so if i had a hoist should be fine does motor need to come out
its not that hard, the one on air con side is a bit of a hassle, you need to unbolt air con from block and move it aside to get in there. i just supported the motor with a jack and timber across the sump and did one side at a time, might need to lift motor 5-10mm to take weight off n line up bolt holes. but pretty simple, just fiddly. and new ones are only $50ish from supercheap ect
oop's, just seen yours is a gtr
Thanks mate cheers for the help guys
