Results 1 to 9 of 9
Thread: VT Calais steering wheel
    VT CALAIS
    May 2010
    VIC
    Default VT Calais steering wheel
    Hay guys, my name is jessie
    Just turned 18 on Friday and bought myself a VT Calais, all in all im pretty happy with the car, has its little things that need to be fixed up but what more can u expect from a 12 year old car, but one of the things i want to fix is the steering wheel, it has a leather one but it is worn and torn, so a replacement is in order, im a bit of a DIY man, so i plan on piking up the wheel when i can and installing it myself, and i was wandering if anyone had done something similar and if so can provide clear instructions, i would like to know about the audio controls as well, will i be able to keep them on the new wheel??, thx in advance
    Jessie
    04 vz clubsport, 6L M6
    Oct 2008
    radelaide
    if you can pick up a calais wheel that has the steering wheel audio controls it should just be a straight swap, surely the wires for these are plugged together and not just full wires running back to the head unit
    also welcome to the forum, you should start a my ride thread in the show us your ride section for vt-vx-wh, it tends to get people a bit more invovled when it comes to seeking advice :thumbs:
    04 z series clubby. 6 litre 6 speed manual
    Quote Originally Posted by Cúl-Báire View Post
    Stroke and Blow it for extra fun!..
    Quote Originally Posted by DM 55 WA
    thats only because instead of porn i look at pictures of your ute!
    VT CALAIS
    May 2010
    VIC
    haha, thx for the advice mate, ill get some info up when asap, but if a calais wheel isnt an option does any1 know of an alternative??
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Before you remove the steering wheel disconnect the battery or you might log an air bag fault thus illuminating the air bag warning light every time you start the car and the only way to reset it is with special equipment. Not only that but there is a risk of deploying the air bag. You will need the radio PIN code after reconnecting the battery.
    Any VT/VX steering wheel will fit and the audio controls can be fitted to it.
    MY RIDE
    VX SS 5.7
    Mar 2009
    North Adelaide
    The steering wheel is very easy to remove.
    You'll Need:
    T30 Torx security bit to remove the airbag
    5/8 Socket to remove the steering wheel
    Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
    Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
    VT CALAIS
    May 2010
    VIC
    ok, thats sweet, i shouldnt have any issues then, also about the airbag light, its been on since i bought the car and it passed a RWC, so i dont know what the go is there but how much is it gonna set me back to fix that suker up??
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Most likely just needs to be reset but it could be a more serious problem. You need to take it to Holden or someone with a Tech 2 to have it reset and they can also tell you what the problem is if resetting doesn't work. Just a reset shouldn't cost much, depends on where you take it. While the light is on the air bags won't work in the event of an accident so for safety sake get it looked at soon.
    MY RIDE
    feg
    feg is offline
    VT S S/C
    Jul 2006
    You can pick up a wheel on ebay. But although any wheel would fit I would recommend keeping the car original and getting a leather one. The series one had a plain leather, and I think either series 2 VT or latter had leather with sections slightly perforated with dots. I think that wheel looks better.
    There are a lot on ebay that are multicoloured, personally I would steer ( whoops pun not intended ) clear of these. Each to there own of course. the problem with buying something like a wheel second hand on ebay will be the condition.
    If it is cheaper you could get just the wheel and reuse the airbag and steering controls from you car. However the airbag or even the clock spring could be part of the issue with your airbag system.
    I've been driving around for years with my airbag waring light on. Mine is just the srs on the drivers seat, I'm fairly sure. But I'm just too lazy to get it fixed.
    I would recommend you get airbag light looked into first because youw ould then know what you need besides just the wheel.
    Good luck and let us know the outcome.
    VT CALAIS
    May 2010
    VIC
    ha ha, no probs boys, i will defiantly be getting a leather wheel, and ill be sticking with a black one, not to keen on the colors, but i will get it to a dealer when Ive got the money, ha ha, and i will defiantly let you guys know how it goes, ill hopefully be getting some picks up when ive cleaned it and it stops raining thx for the advice guys
  1. [SA] FS: VP Calais Tan Steering Wheel
    By PREDATR in forum Parts And Other Items For Sale
    Last Post: 04-08-2009, 08:24 PM
  2. [SA] vp calais steering wheel
    By VPS2 in forum Parts And Other Items For Sale
    Last Post: 03-07-2009, 12:46 AM
  3. [VIC] WTB: VN/VP calais/SS steering wheel
    By bj42turbo in forum Swap / Wanted to Buy / Trade
    Last Post: 08-06-2009, 05:46 PM
  4. WTB: VN/VP Calais or SS Steering Wheel
    By vsuterus in forum Swap / Wanted to Buy / Trade
    Last Post: 24-10-2005, 05:18 PM
  5. VS Calais Steering Wheel
    By Secki in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2005, 09:08 PM
