Results 1 to 2 of 2
Thread: Low Coolant Light
    VT SS SERIES 2
    May 2008
    Default Low Coolant Light
    G'Day guys, I have a 2000 VTII LS1 and as the title suggests I have a problem with my low coolant light coming on when it wants to.
    I'm fine with my coolant level,the temp on the dash is perfect it sit's between quarter and halfway, I have changed the sensor in the bottom of the reservoir,I have changed all of the fuses in the car and it still lights up with a
    mind of it's own. Has this happened to anyone or is my P.O.S dicking me around again
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Are you definately sure the cooling system has been bled properly and you dont have a pesky air pocket causing the problem? And have you checked the error codes? Im not sure but maybe it needs an error code cleared before it will reset. Just a thought..
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  3. Low level coolant light staying on, even though coolant has been topped up
    By luckyluciano in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2010, 08:40 AM
  4. About coolant tube and motor light.
    By Shaunn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2010, 10:04 AM
  5. Coolant Level Sensor/Warning Light
    By mulligan-can in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-06-2008, 12:20 PM
