i got a vu ss its hard to start when cold i turn the key till the lights come on in the dash then weight for them to go off then try to to start it sometimes it works sometimes it doesnt just wondering what it could be like sparkplugs or cpu or fuel filter or a sensor any ideas wld be great thanks 89jas
When you say it is hard to start do you mean the starter turns over OK but the engine wont fire or do you mean the starter wont turn over.
Sounds like cold weather and a weak battery. Do the dash lights dim very noticably when the starter is cranking?
i have the same problem with my car sometimes... it turns over but doesn't fire... its like trying to start with no fuel. I think its the fuel pump as i cannot hear the hum just before starting. its worse in the morning when its been sitting without starting for a while. i need to check leads and plugs as well...
if anyone knows anything else that can be checked would be great![]()
it turns ok but it doesnt fire the lights dont go dim at all thanks guys
Check your connections to your starter motor is ok. Otherwise it could be your starter motor or starter relay is on its way out.
i replace the fuel pump that seem like it was the problem but it wasnt found out are week later it was the fuel pump relay so it all soughted now
