Results 1 to 2 of 2
Thread: Just fitted new regulator not charging PLEASE HELP
    99 VT Sedan
    Feb 2010
    Default Just fitted new regulator not charging PLEASE HELP
    I fitted new regulator charging at 14.2 volts at 2500 rpm with battery light off but After 10 minutes of new regulator fitted drop to 11.7 volts at 2500 rpms with battery light on
    Befor i fitted regulator i cleaned .sandpaper.all contact points on battery terimals and alternator
    cleaned all earths i could find in engine bay...But couldn't find main earth on block
    But i got a set of jumper leads put onto neg terminal with it off battery until i found got earth
    So reconnected with jumper leads on battery and earth on jumpers to see if i have a earth problem
    Made no differance
    With new regulater all leads were showing similar to battery
    And brushes showing 0.6 volts lower than battery
    Engine off at battery 11.7v
    But now at idle drop to 11.2 v
    all points including brushes were about the same
    But what is weird i put old regulator
    Battery and other leads around the same but
    Brushes were only showing 1.55 v and 3.2 v
    So is this a way to tell old regulator is stuffed????????
    But what about new regulator its not charging and theres power to the cables...
    So what do i need to do to make 100% sure my alternator?????????
    I am out of ideas
    Please help
    So
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The best thing to do is take it to an auto electrician. The usually don't charge much just to diagnose a problem, sometimes they won't charge you at all if it doesn't take long.
    MY RIDE
  1. over charging?
    By chaster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2010, 05:50 PM
  2. Not Charging
    By ])R@G()N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2010, 01:41 AM
  3. VTii V6 alternator regulator dead, stuck in nowra - dodgying in another regulator?
    By Rendrag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2010, 09:01 PM
  4. charging
    By Mr Ute in forum Yella Terra
    Last Post: 27-04-2007, 03:29 PM
  5. Charging my phone....
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2005, 05:15 PM
