Results 1 to 12 of 12
Thread: 4l60-e questions
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Default 4l60-e questions
    Kind of have an auto gearbox issue in my LS1 VX. I know it's the 4l60-e, but just wondering if all the auto's from VR were the same, coz if I can get one from a VS or VT then that would be a bit cheaper and easier for me.
    Also are the V8 gearboxes different from the V6's? And will a 5L V8 auto fit behind the 5.7?
    VX Acclaim sc L67
    Mar 2009
    nth qld
    The aut behind your ls1 is a 4l65e which is basicly a beefed up version of the 4l60e.
    and no a vr auto is th700. Not the same
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by wogstyler View Post
    the th700 and the 4l60-e are the same box, its just they used to be called the th700 but changed the name, from what ive read the 4l60-e started from vr and they still use it in the ve
    to the op, you need to get a 4l65e as said above
    "A life lived in fear is a life half lived"
    Feb 2010
    Echuca
    Quote Originally Posted by kniever View Post
    hmmm, I thought it had the 4l60-e, I didn't think they brought the 4l65 in till a few years after. But a 4l65-e would be better anyway if I can get one.
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by sleepa View Post
    yeh sorry buddy you would be right, this write up is from another forum. i wonder if you can bolt a 4l65-e straight up to an ls1?
    Hydra-Matic 4L60-E (M30) /4L65-E (M32) Transmission
    Type: Four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with torque converter clutch
    Engine range: 2.8L - 5.7L (M30) & 6L (M32)
    Maximum engine torque:
    360lb-ft (488 Nm) (M30) & 400 lb-ft (542 Nm) (M32)
    Maximum gearbox torque:
    610lb-ft (827 Nm) (M30) & 670 lb-ft (910 Nm) (M32)
    Gear ratios:
    First: 3.06
    Second: 1.63
    Third: 1
    Fourth: 0.7
    Reverse: 2.29
    Maximum shift speed (M30):
    1-2 6100 rpm
    2-3 6100 rpm
    3-4 6100 rpm
    Maximum shift speed (M32):
    1-2 6400 rpm
    2-3 6200 rpm
    3-4 5600 rpm
    Maximum validated gross vehicle weight: up to 8600 lb (3900 kg)
    7-position quadrant: P, R, N, OD, D, 2, 1
    Case material: Die cast aluminum
    Shift pattern: (2) two-way on/off solenoids
    Shift quality: Variable bleed solenoid
    Torque Converter Clutch: Pulse width modulated solenoid control
    Converter size: 245, 258, 280, 300mm (M30) or 300 mm (M32)
    Fluid type: DEXRON III
    Transmission Weight: wet: 74 kg (M30) or wet: 88.3 kg (M32)
    Bottom Pan Removal: 7.9L 245-mm converter or 10.8L 300-mm converter
    Pressure taps available: Line Pressure
    Assembly Sites: Toledo, Ohio, Romulus, Michigan , Ramos Arizpe, Mexico
    VY SII HBD Calais L67
    Dec 2006
    VX came out with a 4L60E. You will need a V8 version and preferably from a VT series 2 (5L and 5.7L have a different bell housing bolt pattern).
    Also a T700 and a 4L60E are not directly interchangable so don't even bother wasting your time on that one lol
    VYII Calais L67
    Feb 2010
    Echuca
    Quote Originally Posted by chargedvx6 View Post
    So you can't fit a 5L gearbox to a 5.7L. Are the V6's actually weaker or have different specs or gear ratios, or will the bolt holes just not line up?
    Will a 4l65-e bolt straight up to the VX LS1, and if so what exactly did they come in and where do I get one?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    V6 4L60E has different input shaft and different bell-housing.
    Ronald Reagan (1986)
    Feb 2010
    Echuca
    Thanks guys, so my only choice is a 4L60-e from a 5.7L V8, or (perhaps) a 4L65-e, Anyone know if they bolt straight up in a VX?
    vt acclaim gen 3
    Jul 2009
    vic
    An auto from the vt ls1 will fit into vx vy etc and vise versa.
    henrytad
    hey everyone, ive always liked the noise of a blow off valve hissing at the change of gear, n was wondering if there is a way to hook one up on a alloytec 3.6L without a turbo?
    Dec 2006
    4L65E needs its own trans settings to be grafted into the tune. It's set up for different base pressures and apply times.
    If your car is tuned or is going to be as soon as the 4L65E goes in it shouldn't be an issue as long as the tuner has the software.
    4L60E or a T56 would be my tip
    VYII Calais L67
    Feb 2010
    Echuca
    Cheers, what would be involved in putting a manual in the vx?
    Is it just a matter of swapping over the torque converter for a clutch, manual box, shifter, and pedal assembly? Or would I need to change the computer over or get it tuned for the manual?
    I suspect only the LS1 versions would fit again.
    And finally I have never driven a manual commodore, so what is the gearbox like? Is it smooth? notchy? firm shifts? Can you cruise around easily? Is the clutch soft as butter or over the top stiff?
    I had a manual 180sx previously, fun to drive, but the gearbox needed warming up for a good 10 mins otherwise it would be notchy, and would be hard to engage first. On full throttle runs it wouldn't go into gear sometimes. And the clutch was a major bitch in traffic. Just want to know if these type of issues are common coz I want a car that is easy to drive, but can go hard when needed.
  1. ECOTEC and 4L60 behaviour
    By VSCristian in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2010, 08:44 PM
  2. weak 4L60 >> U might be next
    By Ls1uMiNa Ss in forum General Discussion
    Last Post: 23-12-2008, 04:46 PM
  3. VR 4L60-E box behind VP motor
    By gazza140356 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2007, 11:49 AM
  4. TH700 to 4L60-E
    By czerwonyVN in forum General
    Last Post: 16-02-2007, 06:06 AM
  5. 4L60 (VP) versus 4L60E pan
    By FXST01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 10:29 PM
