Results 1 to 6 of 6
Thread: Jessies VT Calais
    VT CALAIS
    May 2010
    VIC
    Default Jessies VT Calais
    Hay all,
    So, my power windows haven't been working for a while now, at least the drivers side doesn't open, beyond the point were u can pry it even now, and the others all open at different paces, i was just wandering how to fix that problem and if it can be done, i tried taking off the door panel today, but was unsuccessful, so i couldn't find a problem, also when i turn on my headlights i get a warning light on my dash just under the speed o needle, not to sure what that means but am hoping someone can help me
    i have started this thread just for my car because there are problems with it and if i can find the solution on here that would be great, i will be getting some pictures up as soon as i have cleaned her up, so u can all have a gander and tell me what u think( open to criticism)
    im sure there be plenty of other problems later on down the track, but these are the 2 main ones that are my worry at the moment
    -cheers
    Vk ls1 turbo
    Aug 2009
    townsville
    feg
    feg is offline
    VT S S/C
    Jul 2006
    just guessing on dash illumination, but the calais are meant to have a warning indicator for tail light failure.
    check the taillights and if not them possibly the number plate light?
    If you don't have anyone to help ( or if you friends are not helpful lol ) you can reverse up to a shopfront and see the lights in the reflection...
    oh and in regards to the windows, perhaps its the switch block, possbily the contacts need cleaning due to a drink being spilled etc.
    just gets some contact cleaner, might be easier than taking all the door trims off.
    VT CALAIS
    May 2010
    VIC
    thx for the advice guys, so i had a bit of a stack the other week amd now need to replce the clips for the front bar, which wont be a hastle, and im also looking to buy 2x 17 inch vt ss rims, or just 1, either wuld be fine.
    i went down to the local auto barn today to buy sum blue parker led's, installed them fine, also when i waz at the shop i bought blue led tube lights for the door card light, and then after that everything turned to shit, im not sure were i went wronf because i did the stupid thing of tackling both tasks at once( jumping from one to the other), and now i get this weird clicking nois from one of the relays behinf the fuse panel under the steering column, has any one ever heard of this before??? HELP!!!!!!
    HAHAHAHA!!!!....they gave me a license
    '98 vt berlina
    Feb 2010
    1. with my vt berlina, the front windows move much quicker than the 2 rear. is that what you observed? i believe that's normal.
    2. the driver side windows get used the most. so it is logical for it to go first. except the problem might be with the switch block like feg said above. when you push the switch did you hear any noise like the motor was trying to turn? is the switch loose as compare to the other 3? the switch block cost me about $160 from holden. what a rip off!!!
    3. check your user manual to see what warning light that is.
    4. as with the clicking noise, try remove the 2 added items in turn to determine which one is causing the problem. then double check your wiring. the clicking noise indicates that you might have wired into the wrong wire to the relay.
    VT CALAIS
    May 2010
    VIC
    haym thx for the reply=),
    1. iwill observe next time in car, but good to know info
    2. im gonna pull off ther card and check when i have the time and clean out motor and wire terminals
    3.dont have a user manual, but just bought one of those service and repair manuals, and the light isnt actual on any more, so might be a loose wire or sumthing
    4.i have removed all 4 globes from doors and stilol have clicking sounds, but when u switch the center console light to the center or most left position the clicking stops, only in the most right position does it click =s, but all interiour lights do not work, which is a shame
    -cheers thank you for reply
  1. [NSW] VK Door trims Berlina & Calais + VL Calais
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 03-10-2009, 07:41 PM
  2. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
  3. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
Tags for this Thread
