Results 1 to 19 of 19
Thread: LSD on VT's ?
    lumina SS
    Dec 2009
    Default LSD on VT's ?
    hello guys.
    All VT's come with LSD diff ?
    I live in middle east, mine got an open diff. i don't know if the previous owner made a swap and installed an open diff instead of the LSD. but now i want an LSD.
    where can i get one ? Or can i get only the internals and convert mine to lsd ?
    what commodore models have the same diff as mine, if i want to buy a used one, will it fit from other models?
    thanks in advance.
    99' VT commodore
    Sep 2009
    Rockvegas
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    is it a series 1 or series 2? i know in the V8 ones they had different diffs. 78 series diff in series 1 and 80 series in series 2
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    the only models were the V8's but they were options on the V6's all including the Super V6, ive got a 9C1 pack and it came with one, its great, if you can get your hands on one you will love it!
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    feg
    feg is offline
    VT S S/C
    Jul 2006
    the lsd or any other type of diff from, vx on, had a differnt connector to the driveshaft. You can update your drive shaft if you can only find an LSD from a later model.
    ebay is a good place to start if you are looking for a second hand one or the internals. I think you may need at least the hi performance or an actual LSD to put in the internals to make it lsd.
    the easiest way to tell if it is lsd, will be the tag on the sump plug stating lsd oil only.
    I did mine in my supercharged 6, definitely worth it.
    here is a link to a site that may give more info on the models and options.
    Unofficial Holden Commodore Archive
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    I just purchased a 98 VT Calais 5L v8, dealer said it had LSD but i couldnt read the tag on the diff cause it was a bit dirty, hopefully it does or its going to cost me.
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
    feg
    feg is offline
    VT S S/C
    Jul 2006
    hey if he said to you it has a lsd, it will cost him not you.
    but there are heaps of posts on here on how to tell if you have an LSD, most of them are jack up the car and rotate one back wheel and see if the other one spins, in the same direction.
    MattyC's Avatar
    VT Calais 5L
    Jun 2009
    Yeah i know how to check, theres a little metal plate that hangs off it and says LSD but i couldnt read it because it was a bit dirty. Hope he wasnt just saying it was... (get the car on Monday so ill check then)
    VT 2
    Nov 2008
    It varies from model to model, series to series.
    Any NA v6 came with a 7.5" crown wheel diff.
    v8's and the super 6 came with a tougher 8" Crown wheel
    As far as I know, only the HSV models came garunteed to have an LSD, although it was a factory option on models.
    Standard LSD is a cone type.
    carless for now
    Feb 2007
    perth,Western Australia
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    MattyC's Avatar
    VT Calais 5L
    Jun 2009
    nah doesnt look like it's got LSD fkn gay..... that just ruins everything.
    I suppose i should ask if anyone can arrange a cheap LSD fitted for me? I have no idea how to go by this.
    I'll post pics tomorrow. extremely pleased with the car, runs very well.
    feg
    feg is offline
    VT S S/C
    Jul 2006
    sorry to hear that.
    still if they said to you it has a lsd, I would chase that up with them, its gotta be against tpa, misrepresentation, or something like that.
    good to hear about the rest of the car, being good. I have never regretted getting an lsd put in mine. it was, $400 off ebay, and another $100 to $200 to get fitted with the right oil etc.
    VT 2
    Nov 2008
    Cheap LSD = Bad.
    Cone Type LSD's need good setup and tooth contact patterns to be tough, durable and not noisy.
    I forked out to get it done right first time. Went from a 3.08 7.5" peg legger to a 3.73 8" LSD on my VT. $1465 with 12 month warranty fitted. Complete rebuild with new bearings and brand new FACTORY GEARSETS. This is the big thing. The metal castings used in the Borg Warner factory gearsets are harder and yet more durable than new repro's. A second hand set with no tooth face wear is much better than a new repro.
    However - setting up pre loads and contact patches properley is not a job to do at home, or for a dodgy backyarder. Take it to and old experienced hand to do it properley.
  15. #15
    VT EX S1 3.8L
    Jan 2006
    going to get mine done tomorrow the pinion bearing has gone so i thought i might as well get it made LSD while its out $750 all up seals oil bearings but im keeping it the same ratio 307 is this a good price?
  16. #16
    vt calais l67
    Jun 2009
    Quote Originally Posted by 6-PAC-ATTACK View Post
    i'd say thats a good price , got a quote recently for the same job but with a gear change and they said around 1500 .
  17. #17
    carless for now
    Feb 2007
    7-800 with the same ratio is about right 14-1500 with a new gears though why you would keep it 3.08 ???
  18. #18
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i have a 5lt v8 ,and on the compliance plate, the axel code no says, i only have standard diff ,check your compliace plate
  19. #19
    vt ss commodore
    Apr 2010
    best way to find out is to do some burnouts on the road, if theres 2 wheel marks shes got LSD
  1. Manual VT's?
    By Anders in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2011, 07:57 PM
  2. Keys for vt's
    By codeunknown in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2010, 06:42 PM
  3. people new to vn-vt's
    By macka75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2010, 10:50 PM
  4. I need someone who knows about vt's!!!
    By missVT195i in forum The Pub
    Last Post: 15-07-2009, 11:29 PM
  5. VT's Suck!...
    By mike_is_bored316 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 09:00 PM
