Results 1 to 9 of 9
Thread: VT FE2 suspension into an 02 vx v8
    mrbeef's Avatar
    mrbeef is offline spongiform encephalopathy
    VX2 V8 Calais/VT V8 Exec ex cop
    Dec 2006
    Whangarei, New Zealand and Newman, WA
    Default VT FE2 suspension into an 02 vx v8
    I am looking to replace my suspension on my vx calais, as the front shocks are well.. shocked so I think I'd do the whole FE2 thing.
    I have a found a set from a VT that are FE2, comes with front struts w/coils and rear coils.
    Will these fit into my VX?
    my bad if this has been covered - too lazy to sift thru search
    Cheers guys
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    It will be a pretty much straight swap, the VT and VX suspension assembly are much the same!
    There is a good DYI thread right here... VX VU:- How to change shocks and springs
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    mrbeef's Avatar
    Dec 2006
    VY SII HBD Calais L67
    Dec 2006
    Same shite. Only difference may be the sway bar links as they changed to a different style on VX. Only cost $80 anyways so it's an easy fix
    VYII Calais L67
    feg
    feg is offline
    VT S S/C
    Jul 2006
    my question is why go older? If you are going to go to all that trouble, I would spend more to get something out of a later model.
    you would want from a later model for two reasons
    a. newer/less wear
    2. later revisions have revisions.
    ( I love that 1 and b joke )
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    The only difference with the front link pins is the bottom of the link that goes on the sway bar is a ball not rubbers/washers. The top is still the same vt-vx-vy
    mrbeef's Avatar
    Dec 2006
    Ok, i may have a found a VY SV6 with fe2 that is being dismantled. Will this fit? Isn't there some v8 springs and then v6 springs? or is fe2 the same across the board
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The front springs are a different rate between the V6 and V8.
    Visit my Facebook page
    mrbeef's Avatar
    Dec 2006
    Ok I got some shocks and springs from apparently a VX SS for 200 bucks posted. I just had a look on the springs the barcode there has number 92048200 on it. Quick search this is for a UTE, will there be an issue here?
LinkBacks (?)
  1. FE2 suspension
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2011, 09:09 AM
  2. Vz Suspension
    By Jimmy SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-08-2009, 06:44 PM
  3. VE suspension vs HSV suspension
    By vcorbs in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-08-2009, 07:11 PM
  4. Vp suspension
    By metlhead666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2008, 07:18 AM
  5. HSV Suspension
    By CSP in forum General
    Last Post: 30-03-2008, 09:14 AM
