Can anyone help me got a 2000 vt Executive S2 v6 wagon 5 speed having problems with it.
Engine light come on while driving then loose all power then comes right it happens 3 times then stalls, Can't start it for about 3- 4 hrs. Replaced ECU but wasn't that. help?
If the engine light comes on then your computer will have a fault code stored in its memory. There will be a thread in here somewhere on how to read fault codes. Just go into search thread which is just above where you posted on the right hand side and you should be able to find all you need to help you.
there was no codes stored in memory tho
Found the problem was, It was the D.F.I. The D.F.I. doesn't store in the E.C.U memory when it faulty.
