Results 1 to 8 of 8
Thread: Question about v6 Supercharged engines
    Still Searching!
    Jul 2009
    Default Question about v6 Supercharged engines
    Hi, Im looking at buying a VT S pack with the supercharged 6. My dad said that this engine has to be run on premium unleaded, but so far on the net ive found that it only needs to run on regular unleaded.
    Does it need to be on premium, and what would result if i just used regular unleaded?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    When i run mine on normal 92 octane it drinks fuel and the exhaust stinks. It looses a fair bit of power too. I dont notice the exhaust stinking when i use E10 but it does use a bit more fuel than if i run premium.
    carless for now
    Feb 2007
    perth,Western Australia
    your dad is correct it should be run on nothing lower than 95 especially if you are modding it
    Still Searching!
    Jul 2009
    carless for now
    Feb 2007
    if you put a 10 psi pulley and such running it lower than 95 can damage your sc
    VS Exec 5spd
    Aug 2008
    Quote Originally Posted by Vt_vic View Post
    how could it possibly damage the supercharger?
    the charger has no idea what kind of fuel is running through the motor, all it cares about is air.
    running higher boost on low octane fuel may risk early detonation, harm to the motor, not the charger.
    carless for now
    Feb 2007
    vt calais l67
    Jun 2009
    run 98 and only 98 at all times .
  1. differences between vs supercharged and non supercharged engine harnesses
    By jwk87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2010, 07:39 PM
  2. vt v6 supercharged computer question
    By omaz78 in forum General
    Last Post: 01-10-2009, 12:12 AM
  3. Question about 355 supercharged and compression ratio
    By Pav in forum V8 Development and Modification
    Last Post: 19-03-2008, 11:31 PM
  4. engines
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 08:23 AM
  5. VT s pack supercharged towing question
    By andrew80 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2005, 01:01 AM
