Results 1 to 20 of 20
Thread: Making exhaust note deeper
    Vt Commodore Acclaim
    Aug 2009
    Default Making exhaust note deeper
    I put a set of pacemaker extractors on my car and I think it made it sound worse. Previously was just a lukey catback. What can i do to make the tone deeper I also have a resonator on the back.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Normally moving the muffler towards the front of your car will make the note deeper. The hard part is finding a mufffler that will fit around your floor pan and not hang down too low.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The larger the muffler will make it deeper.
    Visit my Facebook page
    1998 VT Acclaim S1
    Feb 2008
    VT Acclaim
    Sep 2009
    Get a good highflow cat. i got pacies, a highflow cat and lukey 2 1/2'' on mine (no resonator) and its deep idle (a mate told me it sounded like it was cammin up the other day :P ) and roars at high revs (as much as an ecotec can ofcourse :P) also come out of your pacies at 2 1/4 into your cat back. hope this helps
    Aug 2009
    It does have the high flow cat on it as well. I would say we have a near identical system but i've got a resonator. I did have complications when I first put the extractors and highflow cat on. The exhaust centre screwed the car pretty good made it so the car wasn't using all its cylinders. Another problem that still remains is that it has a miss when I rev it dunno what the problem is there but never existed before I put the extractors and high flow cat.
    VT Acclaim
    Sep 2009
    Did you pull off the leads when you put the extractors on? If you did, check if they are on the right plugs. you may have also damaged a lead when pulling them off (they can be damaged easily) Im pretty sure the cylinders are numbered from front right to back left (standing at the front facing the windscreen) check your leads and if it still misses you might need a new set.
    vr 5s statesman
    May 2010
    VT Calais V6
    Aug 2007
    Quote Originally Posted by My99VTACCLAIM View Post
    I did a full exhaust years ago on a VR Statesman. It had Advance headers center muffler and resonator. Sounded really low and good almost like a V8 and actually fooled a lot of guys and went really good also for a 6, but interesting how you said yours has a miss when you rev it cause I had the same problem. No one could ever work out why it had this miss but it didn't affect how it ran as it only missed when you gave it a rev out of gear. I eventually had to put another engine in it cause that one cooked but it never had that miss with the new engine.
    Aug 2009
    Quote Originally Posted by barra218 View Post
    When the problem first occured and I took it back to the exhaust centre they thought it was the leads and they put a new set of leads on and it didn't fix the problem. Thanks for the advice though.
    Aug 2009
    I talked with the exhaust centre today and they said what they could do is change the pipe from the centre muffler (Lukey) and make it a 3 inch pipe rather then a 2.5 and put a 3 inch resonator on the back.
    VT Acclaim
    Sep 2009
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Aug 2009
    I've got a great exhaust centre here. They only want $200 for the resonator and 3 inch pipe
  15. #15
    Aug 2009
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I've heard twin 2.5"on a V6 N/A was a bad idea.
    When i did the VP exhaust we played with many resonators until i was happy. we went from soft to growl to deep. That rear muffler can do wonders to the note sound.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  17. #17
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    an exhaust is an exhaust, youlgain few kw from rght size but big whoop, not like itl amke a BIG diference, do what you like, and getur resonator, empty it out, itl be deeper
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  18. #18
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Cubes and slugs give you a great exhaust note. 304/8 of them seem to give the best - nfi why, just does. More cubes doesn't hurt. Less slugs seem to sound like a broken hoover.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  19. #19
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    I've never heard a 3 inch is a bad idea. Where did you hear that?
    Exhaust centres. Back in the day I was going to put a 3" on my EF XR6, and every place I rang said nope, 2.5 is biggest you can put on a 6. Any bigger and it would DEcrease performance and wouldnt sound decent either.
  20. #20
    VT Acclaim
    Sep 2009
    3'' is said to be bad for 6's because the exhaust cools down too quickly and therefore doesn't move through the pipe as easy. but if it sounds good, who cares :P though i've never personally heard a single 3 on a 6
  1. exhaust note
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2010, 07:31 PM
  2. exhaust note through sub?
    By VS304exec in forum Car Audio
    Last Post: 07-02-2010, 11:26 AM
  3. 2nd Hole Mod Exhaust Note
    By [Linkin Park] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-01-2010, 06:25 PM
  4. exhaust note
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2005, 10:08 AM
