Results 1 to 6 of 6
Thread: Headlights blowing + BCM Replacement
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Question Headlights blowing + BCM Replacement
    Posting this for a mate, did a search and couldn't find anything. Headlights are blowing on a VT Berlina, would this be something to do with the BCM on the way out? He's told me his BCM is on the way out because he had issues with the power windows not long ago, but this was bypassed somehow, and now his headlights are blowing on a weekly basis.
    Also looking at replacing the BCM, how hard will it be to replace? I understand that the key heads have to be supplied with the BCM, otherwise will have to get keys programmed to the BCM. Also understand that the BCM has to be programmed to the ECU with a tech 2, is there anything else we should be aware of?
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    It could be a faulty voltage regulator in the alternator causing the bulbs to blow. I had the same problem on a machine i used to drive where it kept blowing globes on work lights and the computer kept shutting down when i turned the lights off. I checked the battery voltage and found i was getting 37Volts on a 24 volt system which should normally run at 27 volts. the voltage regulator was the cause.
    On a 12 Volt system you should not reach above 14Volts at any time.
    VT 50th anniversary
    Jun 2010
    Gold Coast, QLD
    My VT has the same problem.. its only ever the drivers side low beam that blows.. am gettin over replacing bulbs every week too!
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Just a tip - do not touch the headlight globes with your bare hands. The oil from your hands causes the globes to blow. If you do accidentally touch the globe, clean the area with methylated spirits.
    VesperZ's Avatar
    VZ Berlina
    Jul 2009
    Sydney, NSW
    I believe I have a followup to this issue. It seems it only happens when it rains, so my theory is the seal that holds the headlight together. Perhaps made need to be resealed.
    See my ride here
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Hey there i am guessing if it only happening when its raining you are getting water inside you headlight assembly causing it to blow or short out .
  1. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  2. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  3. VZ Headlights to Projector Headlights
    By harvs01 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2009, 05:27 PM
  4. Headlights cutting out / fuse block terminal replacement
    By crazyspoon05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2008, 01:32 AM
  5. blowing alot of headlights
    By BANKS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-10-2007, 12:35 PM
