Hi, Im looking at a supercharged VTII S on the weekend and its got 222,300 on it.
Theyre asking $5999 for it, and its got ABS, traction control and vy ss rims on it.
Just after opinions on the price, and also want to know what i should check for when i look at it.
same things as anycar but be wary of any engine rattles
So nothing extra that vts with the amount of kays on it usually have?
And nothing extra with the supercharger?
Is it a series I or Series II
With VT's watch out what series they are! If it is a series II that it is more refined and some parts that might fail will be gernerally cheaper than a Series I. I got stuck with a sI and have had to replace a few things not to bad thro! Its just some series I VT's had common problems and issues that fased out on the series II and in some cases altogether on the VX model.
In sayin that it depends on the life that the car has had (you know thrashed or not, serviced or not)
I would just look for a service history and the parts that have been replaced if known
Danny
Need a V8 or Turbo...!
Sorry didnt see the SII part! Um just make sure the supercharger is working firstmy brother looked at a s/c calais and the supercharger wasnt kicking in properly. listen out for any whining noises either frount end or trans, diff etc.
And deffs check over the service history!!!
i would check odd sounds in the engine, odd sounds from drive line and the diff. Check sump, has it got wear marks from rubbing, meaning needs mounts, have the wheels got scrub marks from hitting gutters, if so, check suspension hasn't been stuffed, check control arms
check the dipstick of milky stuff as the LIM gaskets go on the charged 6s.
+1 for lim gasket.
check the coolant, or even just ask if the lim was changed over for a metal one.
as well there is a website, lists common issue that you should check over listed at the top of the topic.
Faults - VT
I can't work out that page however.
realistically, I don't think there were substantial changes between, series 1 and 2 for the supercharged model. The made slight cosmetic changes, and the seat covers. personally I think the early seat covers and look was better. The original series 2 mags, looked better too IMHO. but with ss mags this won't be an issue. you will have 17s or 18s.
for that price you are getting a good deal, as long as it has been serviced often and not pranged.
Ok then, I'll keep all this in mind. thanks!
hey 11gothevt11
Ive had the car for about 6months and so far i have had to buy new front rotors, buying a sway bar link kit because the current bushes are worn and making noises (like a cracking sound), have to replace the front wheel bearing hubs when i can find a cheap second hand set and just a few were and tear things.
It just depends on how you treat your car or in my case how the last owner treated it :P
Danny
hahha common problems :P !! Nah my hubs are bad especially the front right one. it makes a winding noise whenever in motion (drives me insane), i have just decided on sticking to new hubs just incase i buy a dodgy set.
Like what imparticular ? i have a airbag warning light that stays on the seatbelt light sensor dosnt work and a couple of dash lights on my climate control dont work, apart from that no!
What hav you had?
Danny
I did have air bag light staying on..I just took it to auto elc and they deleted the error $50...Hav't seen it since been 1 year
Sometimes my car cuts out and lights on for trac off and abs off..
But only happenes around once a month...So doesn't bother me but for the last 2 months it hasn't happen......But if it happens more offten i will buy a reco abs..$150 ebay...And just changed new alternator $270 deliverd ebay
There is to many flippen computers!!!!!!!!!!!!!!!
Don't know what next will happen????
Thanks
I have a series 2 VX Calais L67 and all this stuff has gone / is going..
Castor Bushes
Link pins
Sttering rack (leaking oil)
Engine mounts, sump is sitting on the k-frame
other than that check the oil cap for milky sludge because it's really common for the LIM gasket to go, but it's much easier to change than the head gasket
I had a look at it and it had been in an accident at some point and was repaired TERRIBLY. overspray over the front fenders, and the front bar didnt even match the car, no panels lined up either. so im gonna keep looking i reckon
