Results 1 to 3 of 3
Thread: VT SI Cracking steering issue!!! Need Advice..
    Non! Sold the Berlina
    Apr 2010
    Eastside, Adelaide, South Australia
    Question VT SI Cracking steering issue!!! Need Advice..
    Hi everyone!
    This is my first post as i am new to the forums, so bare with me!
    I have a 1998 VT Berlina V6. it has done 173,000ks so far and recently (past month) a cracking noise has came about when steering at low speeds. but lately even when I have been traveling at 50 or 60 sudden movement in the steering wheel will still result in the cracking.
    I had it serviced last Friday and was told that it is the 'sway bar bushes'! I was told it is easy to do you self if you can get under the car and that the best option is to get the nolathane sway bar bushes in a kit new!
    Has anyone had this issue before and have some advice? is it a easy job and what would you recommend !?
    Any comments would be greatly appreciated
    Dannyboy
    Need a V8 or Turbo...!
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Sway bar bushes are a common problem. The factory ones normally only last 80000Km. Nolathane ones are supposed to be the go. You can buy them at Repco. It is an easy job to replace them just make sure you undo both sides at once and keep your car on level ground when you change them. You can buy swaybar link kits which have a bent link that is supposed to reduce wear on the bushes. If you have a look in the search thread there should be heaps of info on swaybar link kits and bushes.
    Apr 2010
    Quote Originally Posted by Tree cutter View Post
    Thanks Tree cutter! yer im deffently goin with the nolathane brand. ive been told that the poly urithane is a longer lasting material so hopefully its a simple DIY task.
    once agian thanks for the pointers and advice
    Regards Danny
  1. steering issue (I think)
    By kb6437 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2008, 01:25 PM
  2. Steering column issue
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2006, 05:17 PM
  3. advice need on gasket issue
    By sircruisealotVS in forum V6 Development And Modification
    Last Post: 13-10-2006, 06:19 PM
  4. Steering Issue *tricky one*
    By brockytt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 04:21 PM
  5. Steering Issue
    By Phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2003, 06:27 PM
