Results 1 to 5 of 5
Thread: need some help to diagnose problem for VT calias!
    Vy 5.7
    Nov 2006
    Default need some help to diagnose problem for VT V6 calais!
    hi guys just recently my car has has started 'wanting' to stall or once in a while stalls(happened only once)...this generally happens when im at low speeds such as 10km/h or very very light throttle...when this happens the orange symbol with the little electric symbol comes on...i prevent the car from stalling by tapping the accelerator or just holding the revs a little higher than idle...but that one time it did stall it struggled to turn on...but when i pulled over and started the engine again after that it started up fine..now im thinking that its an electrical fault...so guys can add to my list of things to change or to do
    list so far:
    new spark plugs (time for service anyway)
    new leads (still got stock leads
    maybe new coilpack (still stock)
    maybe new starter motor (still stock)
    check AFM or throttle body
    new filter
    im getting worried because i feel sometimes that it wants to stall out of nowhere and im worried that if it happens around a corner this might cause a problem for me...so guys i really need some help to diagnose or change...so any ideas are welcome
    Ryan
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When the check engine warning light comes on it should log a fault code. You will need to have the fault codes read to find out what the problem is. Being a 5.7 litre you will probably need to go to Holden to have this done because you can't read them yourself as you can with a V6.
    MY RIDE
    Vy 5.7
    Nov 2006
    sorry this if for my VT V6 calais...not the gen3...the VT is my daily...out of curiousity how do i check for codes coz i haven't had these problems before
    Ryan
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    This thread will explain how to read the fault codes in a V6: Checking error codes VT/VX
    MY RIDE
    Vy 5.7
    Nov 2006
    apart from the codes is there anything elsse i should do?
  1. Diagnose my engine
    By VSSECO in forum V6 Development And Modification
    Last Post: 06-01-2010, 03:39 PM
  2. Diagnose DVD player problem!
    By Bobski in forum Car Audio
    Last Post: 08-12-2009, 05:37 PM
  3. help diagnose my climate control problem pls?
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-02-2009, 04:14 PM
  4. Diagnose my gearbox problem for me :)
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2007, 09:44 PM
  5. Problem with my VR CALIAS! Need HELP! Plz
    By KrystalVRCALAIS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2005, 03:36 PM
