Results 1 to 11 of 11
Thread: vt climate control problems, please help
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    Default vt climate control problems, please help
    hey guys, my climate control in my vt seems to work fine but it doesnt change vents its allways on face and front window, doesnt matter how many times i push the mode button lol, i mostly like my heater to only be on the feet position
    anyone know what the problem could be?
    all help much appreciated
    cheers
    doin skids for the kids and doughnuts for the grown ups
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    Have a search on here, there's plenty of threads on it. Sounds like a vac leak.
    QldKev
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A good place to start is by checking the thin vacuum hose at the rear of the intake manifold, make sure it is connected and in good condition.
    MY RIDE
    slepar's Avatar
    vn ss
    Mar 2007
    Quote Originally Posted by QldKev View Post
    QldKev
    i tried searching, couldnt really find the same problem
    slepar's Avatar
    vn ss
    Mar 2007
    Quote Originally Posted by accentstencil View Post
    i will do, could a split in the hose really caus it not to change vents? i was thinking my climate control panel might be faulty or something
    VT Calais
    Mar 2009
    SA - Victor Harbor
    could be the vacuum solenoid pack under the glove box, have same problem in my calais atm
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by slepar View Post
    Yes, split in the hose could definitely do that because the vents change by vacuum. As lufkin said, it could also be the solenoid pack but the vacuum hose is often the problem and is the easiest to check.
    MY RIDE
    slepar's Avatar
    vn ss
    Mar 2007
    ok mate, i will check for obvious signs like splits or cracks but if i cant find anything obvious what should i do? i guess start the car and put the heater on and listen for a hissing noise?
    slepar's Avatar
    vn ss
    Mar 2007
    ok i had a look today after work, the hose looks fine, i also had a look under the glove box for the solenoid pack but i dont really know what im looking for can some one maybe take a pic for me please or give me a good description of what it looks like? also a quick rundown on how to change it wouldnt go a strai
    cheers
    slepar's Avatar
    vn ss
    Mar 2007
    '98 vt berlina
    Feb 2010
    cheers
    just need to clarify what you said. the air is blowing out of the face window or front window, as in the vent at the centre of the dash right? if so it won't be a vacuum leak because the default position is at the windscreen or demister mode. i knew this because i had that problem only recently.
    a stuck/dislodged vacuum actuator arm, or clogged vacuum solenoid pack might cause that problem though.
    when you change mode at the climate control, does the lcd indicator actually showing the changes? if it doesn't the switch itself might be faulty.
    if it does it might be what i said earlier, or an electrical problem (hope not).
    read this thread for some useful infos:
    VT Climate Control (Vacuum??) Problem?
  1. vr climate control problems
    By vpcommo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2009, 08:23 PM
  2. Climate control problems
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2008, 08:09 AM
  3. Climate Control Problems
    By dashortman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2006, 11:21 AM
  4. VS Climate Control Problems
    By robert_buntine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 03:28 PM
  5. Climate Control Problems
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 12:00 PM
