Results 1 to 4 of 4
Thread: Lost power at 110 kls PH (now dead)
    VS
    Aug 2007
    Default Lost power at 110 kls PH (now dead)
    Hi guys looking for some help here.I’m not very well and having problems staying at the key board.
    I did see a self diagnostics procedure in finding what the problem was with my old VS but now have a dead VX.
    The car was cruising at 110kls per hour and lost power and could not be restarted.
    Now is there a diagnostics procedure for the VX where a wire shorts out a plug and you get some numbers seen on the dash.
    Any help would be appreciated as I had to leave the car 300 kls from home at a friends place and he will have a go at fixing it for me.
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If it is a V6 then the above procedure will work, but if it is a V8 then you will need a Tech 2 to read the codes.
    MY RIDE
    Jun 2005
    Probably same thing as mine. Whats your battery voltage. Voltage regulator on the alternator could be dead
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  1. SV6 has lost power
    By torana355 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-07-2011, 11:47 AM
  2. Lost power ??
    By Comm99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2008, 03:18 PM
  3. you would not believe how much power i lost
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2008, 12:30 PM
  4. car has lost its power
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 10:28 PM
  5. I lost i Just need a little more power..But HOW?
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 01:19 AM
