Hey guys
my vx Calais passenger side lock (inside the car) has seem to
have come loose and is not sticking to it's cut out in the door trim,
know I can wHere it was originally glued but it just not sticking
what can I do ?
It is not glued it is held in with a screw. I assume you are talking about the snipper button (the part that moves up and down). If so, pull the button up and with a very fine screwdriver or something similar, lever the red section of the button out. This will enable you to pull the button right off revealing the part where the screw goes. When you put it back together just put the snipper button back in position and click the red section back in.
MY RIDE
thanks mate i will do that tomorrow![]()
i did it tonight (i had some time) and it was easy with your instruction so thanks,
as you can tell i am not full of car knowledge
So thank you
Scotty
