Results 1 to 5 of 5
Thread: Q about speakers
    VE SV6 MY10
    May 2010
    Default Q about speakers
    Installed my headunit in my 98 VT today and the rear right speaker does not work. Double checked the wiring on the head unit and it is fine? Has anyone else had trouble like this? Could the wiring at the speaker have come loose? Any tips would be appreciated
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A wire for the speaker is probably broken in the door loom in the rubber boot between the door and body. Sometimes if you open the door the wire will contact again and the speaker will work if that happens you will need to repair the wire. Even if that doesn't happen the break will still probably be there. It happens a lot.
    MY RIDE
    VE SV6 MY10
    May 2010
    Quote Originally Posted by accentstencil View Post
    So best option would be to take the door trim off and re-connect?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by MingeyMatt View Post
    I've never had to repair one but I don't think you will be able to fix it by taking the door trim off because the break will be in the boot itself. I would suggest disconnecting the loom at the body and the boot at the door and try to peel back the boot, that is if it is a series 1. If you have a series 2 it will be easier, you will only need to unplug the boot at the body and the door
    MY RIDE
    VE SV6 MY10
    May 2010
    Thanks, will give it a try
  1. Speakers - sub woofer vs 9 x 6 speakers
    By adelaide paul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 11:15 AM
  2. #$%&n speakers
    By omaz78 in forum Car Audio
    Last Post: 01-01-2009, 06:07 AM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  5. Need new speakers for VR
    By tysons_2001 in forum Car Audio
    Last Post: 24-08-2005, 03:09 PM
