Results 1 to 7 of 7
Thread: fuel guzzling V6?
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    Default fuel guzzling V6?
    so i just fueled up today...280km from a tank (city) WTF!!! thats roughly 16-17L/100km. however on highway drives i average between 8-10L/100. I only have to drive a short distance to work and have noticed that by the time im there my temp guage has only just lifted, i was thinking this could be apart of the problem as im lead to believe more fuel is used when cold?. 95% of the driving was grandma style staying under 2800rpm at all times...
    i've done a little search and have found that oxy sensors and coolant temp sensors seem to be the main problems.
    thoughts?
    VZ SV6
    Oct 2008
    Newcastle NSW
    Also thermostat if its taking forever to heat up...
    Start with the basics, its been serviced recently yeah? Tyre pressures, wheel alignment, engine oil has been replaced.... plugs, air filter et. al. .... its idling fine and not misfiring/shaking? Test resistance of the leads with a multimeter...
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    yer plugs, leads, air filter, tyre pressures are all ok...due for a oil/filter change. im not 100% but i think i changed the thermostat last year...
    i might just service it and see if it makes a difference...
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by drift-it View Post
    Make sure you have thermosat fitted ..
    Also have a look at it see whats the opening tem on it..
    Its ingraved on the thermosat
    99 VT Sedan
    Feb 2010
    [QUOTE=11gothevt11;1565272]Make sure you have thermosat fitted .. Just a thought Might be stuck open???
    but I have only heard they get stuck shut...
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Dirty fuel filter will make it use more fuel too because you loose fuel pressure and the injectors dont spray a fine mist of fuel like they should. Oxygen sensors should only make a difference when cruising on the highway.
    vn exc
    Apr 2009
    Hey I have vn v6 and it does 320 kms to a tank round town and that's till empy cause when I fill up it takes 60 ltrs and no I dnt flog It I drive Like a granny
  1. VN idling ruff, backfiring, loss of power, guzzling fuel
    By VN_Pretz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2009, 03:28 PM
  2. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  3. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  4. v6 ecotec guzzling fuel
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2006, 12:42 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
