Results 1 to 12 of 12
Thread: Lowering VT, Trouble removing rear springs!
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    Default Lowering VT, Trouble removing rear springs!
    Yeah I know there is hundreds of threads about lowering VT's but I am struggling to find an answer to what I want to know...
    So today I tired using the tired and true method of spring clamps to compress the rear springs in order to remove them, and replace them with the Superlow springs I have (I used the how to on this site). But I can not for the life of me get the spring off it's seat and out. The spring is loose but there just isn't enough clearance to get it over (under?) the lug mounted on the body that holds them in position. I tried putting weight on the axle, but it feels like the rear shock is topping out.
    So my question, what other methods are there of getting the rear springs out? Will dropping the shock out make a difference (making the rear end unsupported), and if so should this be done from the top or bottom of the shock?
    Any help would be greatly appreciated!
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    Dec 2008
    Brisbane, QLD
    Well found my answer on Google, which Googled me back to here coincidentally enough!
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    undoing the bottom of the shock will help, i undid mine when i changed my rear springs
    you might need to compress the spring more too
    VX II Calais LS1
    Jan 2010
    IRS rear ends are easy to change the springs, all you have to do is undo the shock mount bolt, then undo the 2 rear bolts holding the diff/cradle to the chassis, the whole diff cradle will drop down a good few inches and out will pop the springs. If you try and force the hub down with out undoing the cradle bolts you will rip the cv boots on the drive shafts.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    car
    Jul 2006
    greensy, melb
    make sure you put b4 and after shots in ya thread
    "A life lived in fear is a life half lived"
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Quote Originally Posted by kniever View Post
    Indeed! As im looking at putting the same springs in mine! Lol. Are you just using the stock shocks with the superlows or are you replacing the shocks as well?
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Dec 2008
    Brisbane, QLD
    Quote Originally Posted by Macca86 View Post
    I'll be sure to update the pictures... I am just changing out the springs, the rear shocks were replaced with some stiffer aftermarket shocks when I brought it.
    Front struts could do with replacing, but this will come later on!
    Wagon Man, handbrake was released!
    Dec 2008
    Brisbane, QLD
    Pics in my ride thread!
    VT calais
    Jul 2010
    hey mate, just wondering are you usuing stock shocks or aftermarket ones?
    VZ Maloo. 6 Speed. OTR. Tune. Some other bitz
    Jul 2010
    make sure the cars either in reverse or neutral and release the handbrake!!!! it will drop lower
    Dec 2008
    Brisbane, QLD
    Quote Originally Posted by VT.man View Post
    Hey mate, I am using FE2 gas shocks in the rear, apparently they are the more expensive of the two available from Holden.
    In the front I am using Boge lowered struts.
  1. Removing Rear Springs
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 07:56 PM
  2. removing front and rear springs..
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-02-2009, 09:42 PM
  3. removing rear springs in vx??
    By ANDREASVX87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 09:26 PM
  4. FS: Rear FE2 30mm? Lowering springs for Vt v6 commodore
    By mrs.vr in forum Parts And Other Items For Sale
    Last Post: 30-08-2008, 01:20 PM
  5. Removing rear VX springs
    By DANNY8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2008, 07:31 PM
