Went to start the car one morning and went to fire up, let go of ignition to early and stalled, now it wont fire up just keep's turnig over. Have checked all fuses and relay's, has spark from coil to dizzy but does not continue through the leads, checked dizzy to see if the rotar button was still turning and everything is fine, also checked computer and just say's everything is normal. Anyone that could help i would greatly appreciate. Thanks
Is the security light in the mode switch flashing while it's trying to start?
MY RIDE
No the light is not flashing while i try starting it. the engine turns over but wont fire.
Replace your ignition module. Silver box that sits on the passenger side guard.
MY RIDE
has to be either cracked cap or rotor
dizzy cap is still good, ignition coil is working, i think it may be the module in the dizzy? also rotor button still spinning. thanks for all the post's. process of elimination unfortunately
sorry i mean the ignition module is still working. thanks bandit for the heads up on that one.
