Results 1 to 5 of 5
Thread: HELP! Removal of pinion flange
    Owned's Avatar
    Owned is offline VZ SV6
    VZ SV6
    Aug 2009
    Question HELP! Removal of pinion flange
    I bought a v2 monaro diff (3:07 Gear ratio) for my vt 5l v8 (3:07 Gear ratio). I have noticed that the flanges are not the same as my flange is round and the flange of the v2 manaro diff is triangular.
    What is the best method to convert them?
    ie; Change the flanges around? (if they fit)
    or, Change the tail shaft?
    Also, if it is the tail shaft that needs to be changed how much will it cost? (approx), form the wreckers? And from what model commodore, will fit my auto gear box to this diff?
    I have an idea that the vx will fit, but I am not sure the splines in the yolk will not fit..
    VX II Calais LS1
    Jan 2010
    you would be better off getting a VP-VT series 1 IRS diff, they are all interchangeable and all have the round flange.
    Ive got 3 IRS diffs for sale VP-VT one LSD and 2 open.
    You might be able to get away with just buying a new tail shaft from the wreckers to suit the VT series II to VZ diff that you have bought.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Owned's Avatar
    VZ SV6
    Aug 2009
    VX II Calais LS1
    Jan 2010
    you would have to take it to a diff specialist to have the center removed then have the pinion removed, and swapped over.
    Could end up costing you what another diff would.
    Owned's Avatar
    VZ SV6
    Aug 2009
    Does anyone know if a vz v6 auto tail shaft would fit the vt ser 1 5ltr auto gear box
  1. VE SS Crown & pinion/Ring & pinion
    By VE_SS_427 in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-05-2010, 09:22 PM
  2. IRS Diff pinion flange.
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2009, 04:34 PM
  3. Diff Flange
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-05-2009, 12:47 AM
  4. Diff Pinion Flange
    Last Post: 19-05-2009, 12:41 PM
  5. Is this the same flange as a stock cat?
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2008, 01:12 PM
