Results 1 to 19 of 19
Thread: Diff oil
    2000 VT S2 Olympic Ediiion
    Feb 2010
    Default Diff oil
    Hi guys Im lokking at doing a full service im not to sure about the diff oil how to do it or even if i should do it I doubt it has ever been changed ive had it for 3 years and the owner before me seam to think cars only need petrol to run as i have replaced alot and even found the original oil filter on when i last serviced it. So what will it do for me if i change it should i bother changing it and if i should how do I do it.
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    it'll only take you 5 mins to do so why not, just undo the drain plug at the bottom of the diff, let it drain, put the plug back in, undo the filler and put oil in til its just under or level with the fill hole
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Quote Originally Posted by jay_wr8 View Post
    you make it sounds so easy and pleasant.
    It is a messy and smelly job haha. did it on my vp, and if its old oil - Yuck., but yes its definetly worth doing.
    The Black Beauty
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It wouldn't hurt to change the diff oil, you won't really notice any difference but it's worth doing. Drain the oil by undoing the drain plug at the bottom. Put new oil in by removing the plug in the centre of the diff. Some diff oil bottles have like a hose on top making refilling easier. It takes 1.65 litres.
    I guess I'm a little late, took a while to look up diff capacity.
    MY RIDE
    Feb 2010
    Thats great help guys I even have the oil already its just i saw the plug on the side of the diff and thought how do u fill it up to the top it will pour out when it reaches half full lol so yeah i have 1.65 litres and will be doin next weekend thanks again guys.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Undo the filler plug first. NO point draining it to find you cannot remove the filler. Use a Tomb thumb or similar to pump in the fluid till it runs out, your done.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by TVR-161 View Post
    +1, pretty sure I got cancer just looking at my old diff oil...
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Feb 2010
    car
    Jul 2006
    greensy, melb
    its the smell, to me it smells like real bad fish oil
    "A life lived in fear is a life half lived"
    Jul 2006
    You will have some left over oil, measure that out and chuck that in first in a sense to flush a lil of the crap out. Man even the diff oil out of the bottle stinks lite sh!t.
    Dec 2009
    Doesn't the diff oil only really needs to be checked and topped up as nessecary in these cars and only replaced at specified intervals only if the car is used for towing?
    danja's Avatar
    Jan 2006
    Towing will accelerate the breakdown of the oil as you'll be seeing higher stresses on the gears, but all oils will eventually break down from a combination of heat, oxidation and frictional loads. The manufacturer may have deemed that the oil will in average use outlast the life expectancy of the car, but it doesn't mean it will perform equally throughout it's life.
    Dec 2009
    Quote Originally Posted by danja View Post
    I think it just comes down to driving style and personal views, there's probably a good reason to change the diff oil if you thrash the car, tow a heavy caravan or want to keep it forever but take the example of someone who drives their car fairly normally, does not tow and keeps it 5 to 10 years there's probably no need to change it. I did the diff oil in my old VN V6 once in the 9 years I owned it, used it for towing once in a blie moon and the diff had nothing wrong with it when I sold it.
    danja's Avatar
    Jan 2006
    Quote Originally Posted by wortus View Post
    I would tend to agree with you, that the benefits of changing it frequently on a car driven "normally" would be marginal at best. Like many things automotive, there's definitely an element of psychology involved. When I bought my VZ, having not known really the history of the car I wanted to try and "reset" everything as much as possible, so I changed all the fluids, filters etc to try and start with a clean slate so-to-speak. How much benefit this really did the car is hard to say, but it was beneficial in that I felt better knowing everything was new and fresh.
    If I were to have owned the car long enough I probably would have done the gear oils every 80,000kms or so, mostly of piece of mind - I have little scientific basis for that figure, again it's probably 80% psychological, and 20% of "it's actually a good idea". The only other thing I'll mention is this - my manual transmission fluid after 70,000kms (and a sample of what it looks like when it's fresh).
  15. #15
    Dec 2009
    What sort of oil is that? It looks like Dexron? I'd imagine a gearbox gets a bit hotter than a diff to so that may be why it has discoulored?
    The other fluids I tend to change more often than recommended are the power steering fluid and I would probably get the auto trans done at about 1/2 what Holden recommend.
    A "clean slate" is also a good idea when you get a "new" car unless you can verify when the fluids were done. I was lucky in that my car had dealer servicing before I got it and they had records of the fluid changes.
  16. #16
    Jul 2006
    I changed mine for the first time at 200,000. I would do it every 80-100,ooo. Apparently Holden left if out of the maintenance regime my accident, not sure how true this is though.
  17. #17
    Feb 2010
    Looks like sambucca to me lol. Yeah I believe alot of it is psychological but if it helps u sleep at night if you know that your car is currently serviced and you have the money then why not. The thing tha I notice the most is my oil out of my oil and transmission I get a nice smooth feel for a couple of weeks when I change it.
  18. #18
    danja's Avatar
    Jan 2006
    Quote Originally Posted by dope505069 View Post
    Wanna buy 4.4L of Sambucca? I've got some on special!
  19. #19
    Jul 2006
    Damn, i dumped 10 litres of Sambuca at the Council oil recycle facility........
  1. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  2. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  3. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  4. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
