Results 1 to 6 of 6
Thread: Power Window BCM Bypass
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Default Power Window BCM Bypass
    Hi guys. I've searched around for this and it's a common issue but I can't seem to find the info I'm after.
    What is the exact procedure for bypassing the BCM for the driver's electric window? I'm assuming I'd just need to join a wire from one loom to a wire on another loom meaning the wire would go from the switch, through the relay and then to the window as opposed to going through the BCM first.
    Any help would be appreciated. Cheers
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    hey mate i did this not long ago... find the wire off the switch harness(pretty sure its green with a red stripe) cut it and join a wire and run that to the drivers kick panel and do the same on the wire in the harness... its only a 5 min job mate when u find the wires but make sure u cut the wire at both ends otherwise it wont work
    VX Executive
    Nov 2008
    Bolton point Newcastle
    do you have a diagram showing how it is done .
    I will be doing the same job in two weeks
    thanks
    Mick1988's Avatar
    Apr 2008
    Thanks Lazza. I've got two VT manuals which should have wiring diagrams in them so I can confirm wire colours. I was pretty sure I just needed to join two wires, but I'm too lazy to try to pull the whole car apart to work out which ones so I'm gonna try to get the colours from a diagram.
    Nov 2009
    SE bris
    u only need to get the kick panel out and pop the power window switch up so u can get to the wiring then run the new wire from the switch to the kick panel area and ya done
    Mick1988's Avatar
    Apr 2008
    I'm going to cut the looms right before the bcm and run the wire around the outside of the BCM. I now have the wiring diagram and I can see exactly which wires to solder. I'll only need to remove the fusebox cover, metal plate and airconditioner ducting under the dash to wire it directly from wire to wire on either end of the BCM
  1. VY Power Window Module Bypass Help PLEASE
    By b.b.dog in forum Electrical Wiring / Questions
    Last Post: 18-05-2010, 08:00 PM
  2. power window
    By mercmet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2010, 11:23 AM
  3. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  4. vn-vs power window kit
    By winton in forum Parts And Other Items For Sale
    Last Post: 09-12-2007, 11:14 PM
  5. power window bypass
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2007, 08:50 PM
