Results 1 to 9 of 9
Thread: Tired Auto Trans? - VT
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Default Tired Auto Trans? - VT
    Im suspecting that my trans needs some attention
    Symptoms that I have noticed:
    * Whilst pulled up in PARK in my driveway on a slight incline, It seems to give abit and roll backwards
    * Whilst driving around 65-70 kph seems to be searching for 3 or 4th
    * Will almost always stay in 2nd for a prolonged period while under high revs off the line ( this may be normal? )
    I have had the car for about 4 years had no problems until these subtle changes i have noticed in the last 6 months
    any help or ideas would be appreciated
    or if im being too paranoid, let me know also
    VS Calais & vh sl
    Dec 2006
    deception bay
    roll back how far? a little bit is normal
    around 70 is when ours finds top gear and does change back an forth quiet easy at thse speeds
    if you plant your foot and hold ours will go out to 120-130 (been to the drags ebough to know this) before changing to 3rd but driving normaly will only hold second a bit long when in power mode.
    About 4 years your well due for a trans service so get that done and it should be sweet and shouldnt cost you any more than $100-$120
    May 2010
    Maybe it doesnt roll back too much, just posted all the little symptons up to eliminate any faults
    I do drive around the city in 60 kph and 70 kph speed zones in 3rd and on some occasions in 80kph speed zones from time to time
    I will shift into D when traveling above 80 and on the Highway
    would it cause wear on the trans doing this?
    Whilst off the line and through 2nd it will pause slightly before shifting into 3rd ( around 5600 rpm. ie rev limit )
    And the shifter has vibration consistently whilst driving
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by Rhin0o8 View Post
    should always apply handbrake before going into park anyways, its only small pin in the trans which if your allowing car to roll back all its weight is on it
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    The vibration could be engine mounts.
    The roll back on the Park is normal, when parking though it is best to chuck it in N, then apply the handbrake and allow that to hold the car. Then apply the P. Other wise you are applying undue pressure/strain on the Park Gear. If you first allow any roll back to occur on the handbrake it stops you one day not having a Park Gear :P
    I've found as soon as you get over 70 my gearbox IMMEDIATELY wants 4th, slightly annoying. I agree with 180sc a Trans service might be the go, just to give it a once over, might make it run that bit smoother.
    Can't really help beyond that, but I really recommend you don't let it rock on the P, just wack the handbrake on first and allow that to take the roll.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    May 2010
    Cheers lufkin on that tip.
    my driveway is near flat no more that 5 degree incline maybe
    I'll get into a habit of pulling up in N and putting on the Handbrake . Cheers
    @ MikeCuzzy Engine Mounts ? possibly. I hope not
    Ive checked a few prices out and found a FULL flush out service for $185
    using Justice Brothers "Super Lubricant" and a process much like a Blood Transfusion
    claims to replace virtualy all the fluid compared to 40% with a normal service
    also includes tightening of the bands where necessary
    anyone heard of this technology in Australia ?.
    VT 50th anniversary
    Jun 2010
    Gold Coast, QLD
    $185 for a full tranny flush is good compared to the price i was given of $350!! :-S
    VXII
    Nov 2009
    Also Rhino08, leave your shifter in D for drive. Your car will decide which gear is best.
    Your lock-up torque converter won't work unless D is selected and you will use more fuel and cause undue wear on fluid, clutches and bands.
    '98 vt berlina
    Feb 2010
    since you always drive on 60-70 zones, why not use the power mode? i believe it helps in preventing the car from shifting the gears up and down all the time due to the lack of torque.
  1. [SA] Wtb: 5l auto trans vn - vs
    By Skidney in forum Swap / Wanted to Buy / Trade
    Last Post: 03-06-2010, 10:42 PM
  2. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  3. Auto trans vs
    By andy_man343 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 02:18 PM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  5. VR auto Trans
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2006, 01:16 AM
