Results 1 to 8 of 8
Thread: VT Commodore Has a tapping noise
    Jodamis's Avatar
    Jodamis is offline HSV911
    VT Aclaim
    Dec 2009
    Default VT Commodore Has a tapping noise
    My 98 Vt, V6 has a loud tapping type of noise. I had the RACQ come over aqnd they said it was the Hydraulic lifters. I then had a mechanic call over and he said it was possible a bent push rod. Now both have been replace and the noise sounds worse. Would anyone know what it could be? It is comming from the passenger sider of the engine only and now it won't start up properly. It also makes the noise with the rocker cover off.
    Thanks in advance
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Define, 'won't start up properly'.
    Ronald Reagan (1986)
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    Jodamis's Avatar
    VT Aclaim
    Dec 2009
    Yes it does, but in order to find out if it was the tappets hitting the rocker cover, the risk of a mess was worth it, as it made the noise even with the cover off. I only attempted to start it for a few seconds.
    Jodamis's Avatar
    VT Aclaim
    Dec 2009
    Hi acarmody.
    it turns over but won't idle. It just tries to start. I am a little worried to force it to run, with the noise.
    VX Berlina
    Apr 2007
    Get an error code check done. Did the noise and the bad idle happen at the same time, or has noise been gradually getting louder?
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    injector tapping?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vt olympic
    Apr 2008
    Default Blaze
    Had the same problem. Took it back to dealerto diagnose - after consulting me they started to dismantle
    engine from the top down. Found that hyd.lifters ALL needed replacement - some if the valve stems had mushroomed (ie the stem had started to minutely hammer out) the camshaft had worn through the case
    hardening on some of the lobes . After replacing ALL components engine rah quietly FOR A WHILE !!
    Am now getting some hyd.lifter clatter on start-up again, 20k later. By the way the engine at the time had
    only done 60k having previously replaced under warranty when car had done 50k.
    Car was never abused - changed oil EVERY 5000k - always took it easy when cold etc etc.
    The head honcho in the service dept took me aside and said that in these engines the centre camshaft
    bearing sometimes spins around blocking the oil feed from the galleries and so the top end is starved for oil.
    GMH would not come to the party - quite rudely said that they had already done enough !!! The exercise cost me $4000.00. No more Holdens for me !
  1. tapping noise
    By mardysholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-01-2010, 10:52 AM
  2. tapping noise in engine
    By cbb01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2006, 06:57 PM
  3. tapping noise inengine
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2006, 12:08 PM
  4. Tapping Noise
    By Bloka in forum General
    Last Post: 24-07-2006, 01:31 PM
  5. Loud Tapping Noise
    By nelly77au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 01:44 PM
Tags for this Thread
